Go to Post Ok maybe you cant stop them, but you can utilize that pretty flashing LED pretty darn well! - Andy Grady [more]
Unread 24-11-2008, 23:36
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
New Ctrl Sys Early Ship - Benchtop Test
Hi -
We received our early shipment of the new control system today....just like Christmas a month early for the team!
We ran through the benchtop test procedure this afternoon, and all worked fine except for Auton mode - following the steps in the benchtop test doc, nothing happened when we enabled Auton mode. This is with the out-of-the-box firmware, image, etc on the cRIO and DS.
Has anyone else run into a similar problem? Trying to determine if this indicates a hardware defect (and we have to get a replacement from FIRST) or simply a problem with the default code that ships on the controller....
Thanks,
Ron
Team 2607 - Programming Mentor
**FIRST EMAIL**/Early Control System Ship Final Details Mark McLeod FIRST E-Mail Blast Archive 0 19-11-2008 14:19
Early Shipment of the New Control System EricVanWyk FRC Control System 3 05-11-2008 13:51
Early shooter test video Qbranch Robot Showcase 2 03-02-2008 15:35
Smithy or other Benchtop Mills/Lathes/CNC Dan Richardson Technical Discussion 6 21-06-2007 22:32
How early in the season did you get to test your programming? EHaskins Programming 18 20-02-2007 00:22
