Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 27-11-2008, 15:55
noxryan's Avatar
noxryan noxryan is offline
AKA: Ryan Schlesinger
FRC #0564 (Digital Impact)
Team Role: Mechanical
noxryan is an unknown quantity at this point
Send a message via AIM to noxryan
2009 Driver Station Dimensions
I know that there was a thread about a month ago with exact dimensions on things like the cRio itself, however, nothing was mentioned about the Driver Station. WPI says the drivers station is "6x4x2" approximately. This does not look very accurate. Also WPI does not show the drivers station in its final housing so I am not sure what these dimensions go to. Unfortunately our team will not be getting our control kit early. I was wondering if any teams who already received their drivers station would be able to provide me with exact dimensions on the blue drivers station, I would really appreciate it.
Thanks,
Ryan
Unread 27-11-2008, 17:38
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: 2009 Driver Station Dimensions
6 1/8" x 4 5/8" x 1 3/16"
The .1" header pins and the competition port stick out another 1/8" each
The competition port enable/disable switch they send us sticks out 2 1/8" in all from the case.
screw heads on the sides take 1/16" each
There's a photo here somewhere...let me look...
I'm told we'll probably want to mount it with velcro.
Unread 27-11-2008, 19:15
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by Mark McLeod View Post
6
What????? They designed this entire thing and left out bolt holes?
Unread 27-11-2008, 19:35
Just Itinerant
Sorry, no bolt holes.
There are four sheet metal screws into the top & bottom holding the case on. One has the warrantee sealing tape over it (they don't want us opening the cover), so that one cannot be touched, but the other three could be used to grab brackets.
I added a photo in the second post to show the side screws.
Unread 27-11-2008, 19:52
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Velcro works well, besides you can mount the router with velcro, then remove it for competition.....leaving room for a small laptop for the dashboard....assuming we can use a laptop, that is
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 27-11-2008, 21:02
noxryan's Avatar
Thanks for the dimensions and the pictures they are a huge help. I plan on putting ours into an enclosed control panel and having the top plate punched with holes for the LCD, buttons, and LED's. I would use Velcro to mount it however, I want to have as little movement as possible on it so i may try and make brackets for those screws you described. I guess we will just have to avoid the screw with the warranty tape over it.
Driver Station Blank Screen, Anyone have the same problem? LDavies562 FRC Control System 14 22-12-2008 19:34
pic: The new driver station Billfred Extra Discussion 28 23-04-2008 20:07
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
