Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 29-11-2008, 16:50
Xaphiinia Xaphiinia is offline
FRC #1983
Xaphiinia is an unknown quantity at this point
[FTC]: Random Error with FTC motor control
We started from the standard 288 base code, which works well except our robot throws an error randomly from the FTC Move Motor.vi that causes it to stop working.
This error will continue the last action of the driver for maybe two seconds and then the robot will stop. We designed a function to indicate that the error has occurred through beeps. The error can be corrected by switching off the battery for approximately five seconds. We cannot figure out what throws the error though. Sometimes the error will throw itself every couple of seconds while other times the robot will run fine indefinitely, or at least until we turn off and on the program.
We modified the 288 scaling code to cap the maximum values in case of weird controller values, so we don’t believe that to be the problem. We also do not use the encoder values in our program.
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
