Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Unread 29-11-2008, 19:42
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
Rookie Year: 2007
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
driver station doesn't see robot
The connection LEDs for the wireless are lit up but the drivers station says no comunication with the robot. However if we turn the DS on and the robot is on the DS reads 0.0 volts until we turn the robot off when it once again reads "No Comms" Windriver also says its downloading fine and we can see both the router and the robot receiver on the computer.
Unread 29-11-2008, 21:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: driver station doesn't see robot
Can you ping the Driver Station and verify that it has the correct IP address corresponding to your team number?
Unread 29-11-2008, 21:52
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
What you're describing here is the correct behavior. The "No Comms" message means the driver station is not receiving reply packets from the cRIO. If the cRIO is turned off then the DS is expected to display "No Comms".
There are four general messages you could expect your DS to display:
"No Comms" means it isn't receiving reply packets from the cRIO
"No Code" means it is receiving reply packets, but the software isn't updating the battery voltage
"0.0 V" probably means you don't have power going to the first 9201 module
"X.Y V" where X.Y is the correct battery voltage means everything is working properly
Unread 29-11-2008, 21:54
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
You could have a number of issues...
1. Did you configure your wireless router and wireless gaming adapter to communicate with one another by inserting the CD that came with the router into a computer?
2. Is the Ethernet cable that is running from the router to the DS plugged in the proper locations?
Just because the DS reads the battery voltage as 0.0v, it does not mean that the two are not communicating with one another. In order for the battery voltage indicator to display properly on the DS, port #7 on the analog breakout must be configured properly.
Please try to limit technical issues/discussions to the FIRST Control System Forum.
Unread 29-11-2008, 23:58
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
I can't double check, but if it says 0.0V then I believe your robot comms are fine and that simply means you haven't hooked up the voltage reader. Can you get the DS to input and then have the cRIO output something?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
2009 Driver Station Dimensions noxryan FRC Control System 5 27-11-2008 21:02
pic: The new driver station Billfred Extra Discussion 28 23-04-2008 20:07
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
