Go to Post We all need to keep things in perspective. When you look back at the entire 2005 FIRST season, is your entire experience defined by the presence of a little cloth flag on the play field? - dlavery [more]
Unread 03-12-2008, 15:22
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Missing Standoffs on Sidecar
Has anyone notice that there are no standoffs on the sidecar to screw down the 37 pin connector to?
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 03-12-2008, 15:51
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Rookie Year: 1999
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Re: Missing Standoffs on Sidecar
yes and they are also missing on the dongle switch that plugs into the operator interface.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 03-12-2008, 17:22
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
yeah, that has been an issue, but its not very loose luckily. On the other hand, the dongle does seem like its ready to fall off of the Linux Box. At least they provided screws for the bumpers because those things are the loosest fit connectors i have used so far.
Unread 03-12-2008, 19:40
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
We did our bench test this evening. We quickly noticed the missing pieces, but we happened to have some in a small parts drawer, so we installed our own. We also noticed the extraneous bits on the other end of the 37-pin cable, and removed them so the connector could attach securely to the cRIO module.
Missing Banners Chris Marra Awards 0 04-05-2007 19:50
missing old_port stephenthe1 Programming 2 17-02-2005 10:09
Am I missing something.. Lord Nerdlinger 3D Animation and Competition 4 19-02-2003 16:06
Missing Mr B archiver 2000 0 23-06-2002 23:10
Missing Ninny Carolyn Duncan Chit-Chat 28 03-08-2001 03:07
