pic: One of Team Overdrive's new toys
Re: pic: One of Team Overdrive's new toys
Wow. What a beauty. I have a 1920's Logan lathe in my garage (same size). Dad has a 12" Southbend with a 6' bed that appears to be the same vintage. I am a huge fan of antique machinery.
My Logan has a built in cover/tensioner over the belt and back gears. It may be a good idea from a safety perspective to cover the belt and back-gears as there is a reason that modern lathes have these gaurds. Oh, used cookie sheets make excellent chip-pans. |
![]() I am planning on adding some guards before I let my teammates start using it. I rather everyone keeps their figures. ![]() |
Awesome. I didn't notice the cookie sheet before, but see it once you pointed it out.
These old lathes can be wonderful machines. I made 6" internal bearing lands for a sports racer a friend and I built. I also cu through 4" of steel for the spool drive. With practise and a good Machinist Handbook (if you don't have one buy one), you will be able to do amazing things. I did update my Logan with a quick release tool changer. This is a significant time saver as the Southbend/Logan 1/2 moon adjuster must be re-aligned every time you change operations. I found a set somewhere for about $250 that had the head unit and 4 tool holders (1 parting tool, 2 turning/facing, and 1 knurler). I kept the old unit, but have not used it since. Here is the Harbor Freight link. I don't think I bought the Harbor Freight unit, but something very similar. http://www.harborfreight.com/cpi/cta...emnumber=34816 |
Well, not me. Ha. Did find an American Scientific pocket guide from 1920 that uses a South Bend to illustrate the functions and implementations of a lathe though, good enough for me. ![]() |
hahahahaha i just finished reading that book. it is really good and i recommend it to anyone who is learning how to use a lathe.
Wish they made one for the mill.
nice i have one but mine a bit older mine ped-metal lathe so you had to pedal it as you worked
i can't see how people could do it it hard to stay balanced as your work |
#10
![]() All freshmen labor jokes aside, it would be very hard to pedal while you machined. -Vivek |
#11
This one has 1/4 hp of pure custom built power. It runs very well for how old it is. Just motor hum, gear clicking, and belt nose only thing I could careless for is backlash, but I have seen worse on much newer. |
#12
Lucky you! That is a fine looking machine.
I see you are from NJ - too bad Henry Ford moved a chunk of Menlo Park and brought it here to Detroit (Dearborn). Because you can see a lot of the early machine tools there. So fun to look at, and not much has changed from the early days of machining. (OK, CNC is a nice add....) |
| [FTC]: Team Overdrive's robots close up photos | Lowfategg | FIRST Tech Challenge | 0 | 26-07-2008 23:05 |
| [FTC]: Team Overdrive's New Video | Lowfategg | FIRST Tech Challenge | 1 | 15-06-2008 20:17 |
| pic: Team Overdrive's #74 robot | Lowfategg | Extra Discussion | 9 | 06-03-2008 16:53 |
| pic: Arefin playing with my toys | Tytus Gerrish | Extra Discussion | 13 | 09-10-2005 23:28 |
