Go to Post Eription- the condition of shredding the eardrum from excessive cheering at robot competitions - Wayne C. [more]
Unread 06-12-2008, 12:42
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
spike relay problem?
On the new control system cRIO we're having a bit of trouble getting the spike relays to work.
We have the code setup to run the relay forward when one button is pushed, and backwards when another is pushed. The forward button works and the relay changes, however, the reverse doesn't. The code is working, you can see the reverse light on the digital sidecar turn on, but the spike will not change like it does for for forward.we've vhecked and replaced the pwm cable several times.
My beleif is that the problem lies in the libraries controlling the pins for the relay switches incorrectly. Has anyone else experienced this problem?
Unread 06-12-2008, 20:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: spike relay problem?
If the light on the digital sidecar is changing as expected, I don't think there's a software issue.
What do you expect to see from the Spike, and why do you expect that? What is it doing instead?
Unread 07-12-2008, 14:06
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
That was my conclusion too
I expect the relay to go forward, reverse and stop.
it only goes forward and stop, even though the digital sidecar is sending the signal, the spike isn't doing anything.
and, yes. I have tried using a different spike relay and cable.
Unread 08-12-2008, 07:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
This may seem like a dumb question but are you using a newer Spike? There was a model change several years ago and previous models responded differently than the modern ones. The old ones were labeled with a red label as I remember.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-12-2008, 08:58
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Are you trying to simultaneously drive the Spike both forward AND reverse?
If you're trying to drive a motor and you set both FWD and REV, the motor will have both leads driven to battery voltage which means 0V across the motor.
You might need to check the logic in your software since you only be asserting either FWD or REV with this type of application.
Russ
Unread 09-04-2012, 13:49
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
I believe that Al is on to something here. We had a similar problem - swapped everything (spike, code, cRIO, wire, etc.) and then tried a VEXPro Spike (we had been using older IFI redlabel/bluelabel Spikes). Suddenly, everything worked as expected.
- Mr. Van
Coach, Robodox
Unread 09-04-2012, 14:03
Unsung FIRST Hero
Rookie Year: 1996
To back up Mark, almost always when the DSC is showing the expected LEDs the problem lies with the PWM cable.
Al
WB9UVJ
www.wildstang.org
Unread 09-04-2012, 19:18
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Or, in this case it looks like a spike issue. the pwm cable checked out fine, but just in case I tried another. I got +5 volts from red/white wires with corresponding button presses that activated forward and then reverse. Seams like something in the spike has failed. To be fair its a fairly old spike pulled off a robot from years back.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 08-12-2008, 10:58
Software Architect
Please tell us what colors the light on the Spike is showing. Yellow means stop. Green means forward. Red means reverse. Off means both forward and reverse at the same time, which is probably what you're telling it to do when you think you're telling it to go from forward to reverse. It's just like stop, except that both outputs are at battery voltage instead of both being at no voltage.
A Spike has two completely independent relays. Forward and Reverse are not two different states of the same relay. They are separate relays which each can either be on or off. If you want to "go in reverse", you have to turn the reverse relay on while simultaneously turning the forward relay off.
Unread 08-12-2008, 18:37
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
I don't know the electrical pin out of the SPIKE control signals, but you could take a volt meter out and check to see if it is sending the signal you expect. I would expect that the manual has that information, or someone on CD knows.
Unread 08-12-2008, 21:51
Dan2081's Avatar
Dan2081 Dan2081 is offline
AKA: Dan
FRC #2081 (Icarus)
Rookie Year: 2007
Dan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to behold
*sneeze*
09 IRI #7seed and Semifinalists
09 BMR GM Industrial Design
08 BMR Engineering Inspiration
08 Archimedes #5 seed
07 BMR Rookie All-Star
Unread 18-02-2012, 13:06
student 1254 student 1254 is offline
FRC #1254
student 1254 is an unknown quantity at this point
Lightbulb Re: spike relay problem?
you should try and bypass the spike and use a victor control. we just did that today and it solved our problem. Now we can go forward and reverse.
Unread 09-04-2012, 13:09
coreyjon's Avatar
Flight Engineer
Did anyone ever figure this out? I am having the same problem. In the programming I have it set that one button is forward, another reverse and when nothing is pressed it is off. The digital side car responds as expected, green light forward, red light reverse, and no lights when off. The spike (blue label IFI) responds to forward (green light on spike, +12 volts), but does nothing when reverse is sent to it. no clicking no nothing. Sending the kOn command turns on both the green and red light on the digital side car and the green light on the spike.
Why no reverse? such an odd problem.
when the command kOn is sent is it activating both internal relays? so I should be getting 12 volts from both output pins when compared to ground on the power distro panel? Just trying to figure out a way to trouble shoot and see if one of the relays are bad, I do not have another spike on hand at the moment to test by just swapping them out.
Unread 09-04-2012, 13:34
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Your code passes muster if the Digital sidecar Relay LEDs are performing as described.
The Spike should reflect what the Sidecar LEDs are doing, although I think the Spike should be yellow for neutral when the Sidecar LEDs are both off.
It sounds as if the code is working through to the Sidecar.
Any of the parts after that could be causing a problem:
  • Sidecar itself (test the Relay pin outputs with a multimeter- relays are a constant 5v on both the red & green signal pins when they are active, 0v when not)
  • PWM cable (test at the far end with a multimeter)
  • Spike (test 12v output on M+ & M- lines to ground)
P.S. It sounds like the red signal line isn't getting through for some reason.
  #15   Spotlight this post!
Unread 09-04-2012, 13:35
coreyjon's Avatar
Flight Engineer
all sound like excellent troubleshooting techniques, will perform and report back.
[OCCRA]: spike relay polarity question bernieseaholm OCCRA Q&A 1 12-11-2008 16:43
Spike relay question Zack Briggs Electrical 17 19-02-2008 14:48
Spike Relay Wire Gauge sparrowkc Electrical 7 12-02-2008 14:26
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
