Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 07-12-2008, 14:14
Edmund Harfmann Edmund Harfmann is offline
Edmund Harfmann will become famous soon enough
MRS 2.0 Interface for VEX released
The VEX Robotics interface now supports MRS 2.0.
http://www.codeplex.com/VexMsrs
This project describes a set of services to support the VEX Robotics controller from Microsoft Robotics Studio 2.0. This release has some major changes to the default handling. Rather than requiring you to set default parameters, each supporting service can search for the controller to setup a working default. (E.g. if the first encoder is set as interrupt 3, then if you create an encoder without a manifest, it will search and find the encoder on interrupt 3.)
There are MANY bug fixes in comparison to the 1.5 version. Responses are now generated after requests are satisfied. New and soon to be released sensors from VEX Robotics are supported. (At least I expect they are since I don't actually have the sensors yet.)
Currently implemented are:
  • Motors
  • Servos
  • Button switch sensors
  • Limit switch sensors
  • Light sensor
  • Sonar sensor
  • Encoders
  • Gyros
  • Accelerometers
  • Analog Inputs/Outputs
  • Digital Inputs/Outputs
A description of the SquareBot robot is included to get started with.
Merry Christmas,
Edmund Harfmann
Release of MSRS interface for the VEX Edmund Harfmann Programming 0 24-07-2007 20:14
MSRS interface for the VEX controller Edmund Harfmann Programming 12 29-06-2007 20:38
pic: Mr. and Mrs. Matt and Angela Leese Joe Ross Extra Discussion 8 11-10-2006 01:44
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
Material for Operator Interface archiver 2001 4 23-06-2002 23:03
