Go to Post The strength of an alliance is not defined strictly by the sum of its parts. - Jared Russell [more]
Unread 07-12-2008, 21:52
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Simple C++ State Machine
I've attached a generic state machine class that could be useful in autonomous programming this year. My team is looking at using the IterativeRobot base class so we needed a way to keep state information in between iterations. I have not yet tested this on a robot but will try to this week as we get our control system setup.
The class uses templates to let you customize things a bit. The first parameter is the state identifier type, we will most likely use an enum, but you could use anything most likely including strings. The other two parameters are for the method callbacks (the class type we are passing an instance of in the constructor and the method signature). You then need to associate states with method callbacks for each state you want to use then set the initial state. During the perodic call the call to CallCurrentState will delegate control to whatever callback you've set using AddStateCallback.
It has been a while since I've written C++ (I work more with C# these days) so this code may be rough. Below is an example I wrote from memory without testing so it definitely won't compile without some work.
Example (not tested):
Code:
#include "StateMachine.h"
enum AutoState
    AUTO_START,
    AUTO_TURN,
    AUTO_GOAL1
class MyBot : public IterativeRobot
private:
    StateMachine<AutoState, MyBot, void (MyBot::*)(void)> *m_state;
public:
    MyBot(void)
        m_state = new StateMachine<AutoState, MyBot, void (MyBot::*)(void)>(this);
        m_state->AddStateCallback(AUTO_START, &MyBot::Autonomous_State_Start);
        m_state->AddStateCallback(AUTO_TURN, &MyBot::Autonomous_State_Turn);
        m_state->AddStateCallback(AUTO_GOAL1, &MyBot::Autonomous_State_Goal1);
    ~MyBot(void)
        delete m_state;
    void AutonomousInit(void)
        m_state->SetCurrentState(AUTO_START);
    void AutonomousPeriodic(void)
        m_state->CallCurrentState();
    void Autonomous_State_Start(void)
        //... DO STUFF ...
        m_state->SetCurrentState(AUTO_TURN);
    void Autonomous_State_Turn(void)
        //... DO STUFF ...
        m_state->SetCurrentState(AUTO_GOAL1);
    void Autonomous_State_Goal1(void)
        //... DO STUFF ...
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
State machine in LabVIEW? JBotAlan National Instruments LabVIEW and Data Acquisition 3 23-10-2008 07:59
Hawaii Gov. Lingle State of State speech-FIRST and STEM MoeMom FIRST In the News... 0 29-01-2008 17:04
2 simple questions RDD Rules/Strategy 4 10-01-2007 16:41
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
