Go to Post You know you're overdosed on FIRST when you see the thread titled "team 228 can and bottle drive" and think "what kind of crazy drivetrain is that?" - Joe G. [more]
Go Back   Chief Delphi > Other > VEX
Unread 07-12-2008, 22:49
SCROSSLEY-GCEC's Avatar
SCROSSLEY-GCEC SCROSSLEY-GCEC is offline
Number One Issue!! :D
Team Role: Mechanical
Rookie Year: 2010
SCROSSLEY-GCEC has a spectacular aura aboutSCROSSLEY-GCEC has a spectacular aura about
Send a message via MSN to SCROSSLEY-GCEC
Tank Track
For the current VEX game 'elevation' my team are currently using a horizontal tank track to storee and deposit cubes.
Everything works perfectly except for one thing,
at the start of the track there is a large lump caused by the sprocket, which means we cannot get cubes over it and on to the track
we didnt think to account for this problem at the beginning (probably should have) and due to a shortage of equipment are unable to find a way to solve it.
can anyone think of any possible solutions - no matter how half-baked they are? we would appreciate it so much as our competition is This Saturday (Monday Now)
thank you all so much
-Steph
(Team GCEC - Auckland, New Zealand)
Please note: We have a severe lack of motors. we have one motor and a ton of servos
Unread 07-12-2008, 22:51
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Tank Track
I don't exactly understand what you mean by "lump." Pictures may help.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 07-12-2008, 22:59
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Tank Track
I think it looks something like this: (rotate 90*)
You could try using a counter-rotating wheel or similar item above the "lump" to guide the cubes in. It can be done without any additional motors-- use gears.
Or--flip the cubes over it using a lever of some form, maybe.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-12-2008, 23:29
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Tank Track
To minimize the lump instead f the drive wheel you could use one of the single bogey wheels. That would make it smaller but not make it disappear.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 08-12-2008, 00:05
Rookie Year: 2010
Re: Tank Track
put a Tank Tread sprocket on its side. that is the height of the end of our track. we are unable to get the cubes over it to get them on the track.
a few good ideas in there - tempted by the lever and definitely going to use the smaller wheel.
or would it work to put a metal plate on the other side of the cube firmly against it and just roll it against that? anyone know?
also, if you put a large gear on a servo with a small gear meshed to it, will the smallgear be able to turn something 360?
Unread 08-12-2008, 00:10
AKA: Bates
FRC #0125 (NUTRONS)
Re: Tank Track
It might turn in 360 degrees once but it would then have to turn back which might cause you to be able to get the cube partway in but before it was all the way in it would get pushed back out. Try it though see what happens.
Unread 08-12-2008, 00:18
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: Tank Track
If you use something attached to a servo to cause the cube to stay in contact with the tread, the tread's friction should soon pull the cube into your system.
The cubes are very light, so you don't need much friction from the tread. Just a little force will be enough to lift the cube up and over your lump.
Use the servo to cause a "hook" to flop down an press against the cube. I say "flop" because you want this hook to "float" and allow the cube to move the direction the tread is trying to take it. The hook needs to be flexible, not rigid.
Sound feasible in your design?
Blake
PS: Yes - A 36 tooth gear mounted on a servo and turning a 12 tooth gear will rotate the 12 tooth gear nearly full circle.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 08-12-2008, 00:29
Rookie Year: 2010
Re: Tank Track
This is great, sounds exactly like what we were looking for. thank you
thanks for all the help everyone, we really appreciate it. wish us luck for saturday
Unread 08-12-2008, 00:47
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Tank Track
Glad to help - Try combining that idea with one of the tread arrangements (in the photos in the other post) that eliminates the need for a sprocket at the intake end of your system...
Time to get some sleep over here on our East coast - Don't forget you owe us all some photos
Blake
Unread 08-12-2008, 00:30
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Tank Track
Cubes aren't cylindrical or spherical.
Consider this: if you look at pickup mechanisms for FRC for 2006 (or 2004, or 2002, or any other FRC or FTC or VRC game involving balls), they were developed for spherical objects, which a flat plate works for. However, VRC's Elevation uses cubes, which aren't spherical, though they could become that way after going through a flat-plate pickup system!
Other ideas could easily be derived from some of the above teams.
Past teams:
Unread 08-12-2008, 01:52
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Re: Tank Track
We used tank-treads-and-a-plate to pick up softballs in the 2006 VRC game, too. Cubes and foam balls were a lot easier.
Our team 575 uses rollers to pinch cubes against a flat plate for lifting. It makes use of a Top Sekrit feature which makes it possible for the cubes to ride smoothly up without getting stuck diagonally. I'll post a picture when I download our pics from the Vancouver tournament. Dromedary (the 575 robot) was 4th after qualifying and lost in the semifinals. This is the robot that won the "Amaze" award.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 08-12-2008, 02:11
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
Re: Tank Track
If the problem is that it is too tight for the cubes to get picked up you could do what many teams do and move the treads farther apart and just put zipties on the tread like paddles and then those would pick up the cubes. I've seen a couple robots do this and it seems to work.
Unread 08-12-2008, 02:37
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
Re: Tank Track
hi, the tank tread idea seems to be a good idea but in the competitions in NZ they don't seem to be working that well. I think for the idea to be reliable you would need to create some sort off suspension between the treads, i had an idea of using slotted plates and standoffs with rubber bands around them to create floating rollers that would let the treads expand to hold the cubes securely (i would like to prototype the idea but unfortunately my team doesn't have a set of treads yet). BTW i really liked your pneumatic claw set up, using steel cable and attaching the cylinder at the end of the arm, i thought it saved a lot of weight at the end of the arm where it counts good luck for Saturday and see you then.
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
Unread 08-12-2008, 23:24
NoahTheBoa's Avatar
FRC #0968 (RAWC)
Re: Tank Track
For a tank tread system to work effectively you should make sure that the tracks are tensioned correctly so that the tread doesn't sag.
  #15   Spotlight this post!
Unread 09-12-2008, 12:41
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Re: Tank Track
Moving the treads apart slightly and using rubber bands or non-skid padding allows sufficient room for the cubes while maintaining grip that "gives."
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Track Design Mrtrom General Forum 1 08-01-2008 23:05
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Track Drive greenz_gurl15 Technical Discussion 1 13-01-2003 23:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
