pic: West Coast Drive: Spokane Style
Re: pic: West Coast Drive: Spokane Style
if you were thinking about climbing, why not use a 2 speed?
i like this design escpecially the bumper mounts |
2 CIMs geared for 10fps doesn't seem traction limited (assuming roughtop/wedgetop tread).
Don't see the correlation between the two things...care to explain? Plenty of 'bots did just fine w/o any shifting in 06, so I don't see what you mean by that.
You definitely do not need a 2 speed transmission to climb things. All a 2 speed would really help with is allow you to be a bit more precise in maneuvering. The important things to consider when having to climb are approach/departure angle, breakover angle, center of gravity, and traction.
I do really like this design although I do favor 2 speed transmissions for the ability to push and to be agile when you want. I'm glad Ive inspired a little West Coast off of sorts. Who's next? O and how much does it weigh? |
Just guessing...the frame is made of 1/8" wall 1x2" aluminum tubing? welded together?
Looks very orthodox, and a good design! |
EDIT: Yeah Squirrel, it's all 2x1x.125 wall extrusion. The goal was to keep the chassis to only one material to keep the cost down, and the BOM simpler |
O I know it's been cooking for a while. You've had a design similar to this floating around for a while now. It's good though to see how different people change and interpret a well known design.
#10
Actually, after reading over what you said, let's see how many iterations of the West Coast Drive there are out there! If you've got one designed, put the render up on www.tinypic.com and throw it up here!
#11
Nice design, that kind of set up has been proven to work tons of times. What kind of guts do you have in the transmissions? Are they completely stock components (minus sideplates), or do some of the shafts/gears need machining?
Comes in to about the same weight as yours, too, about 35 lbs with chain (says inventor). The transmissions are about as itty bitty as they can be.![]() |
#12
Why is cantilevered better than non-cantilevered? Beats me. We won't be doing this again. |
#13
Chassis weight. You need less chassis material for a cantilevered drive base. There's no need for an outer frame rail, which definitely takes weight down.
#14
Pics of specifics would greatly help. |
#15
Cantilevered means the axle is supported at one end or a the center, non-cantilevered the axle is supported on both sides of the wheel.
| "West Coast" drive? | pogenwurst | Technical Discussion | 32 | 17-12-2008 19:50 |
| pic: West Coast SS mounting 3 | AdamHeard | Extra Discussion | 2 | 17-06-2008 13:11 |
| pic: West Coast Altered | Alex.Norton | Extra Discussion | 25 | 13-06-2008 00:13 |
| pic: West Coast Collaborationz and Team 254 Present | phrozen solyd | Robot Showcase | 22 | 28-02-2005 01:31 |
| East Coast, West Coast, and Midwest FIRST | Aaron Lussier | General Forum | 52 | 04-08-2003 01:52 |
