Programming Question
I am a novice at easyC so here is my question.
Why when I am programming my VEX robot using easyC v2 my robot does not respond the same way when bumper != 0 or bumper == 1: Can some one tell me why? ahh: |
Re: Programming Question
C has a number of tests for comparing two numerical values:
== tests if the two values are exactly equal != tests if the two values are not equal So the expression (bumper != 0) literally means "the value of bumper does not equal zero", it could be any value at all, other than zero, i.e. bumper could contain 3 and this expression would be true. Where as the expression (bumper == 1) literally means "bumper is exactly 1". In the above example if bumper were 3 this would be false. So for the values of bumper equal to 0 and 1, the two expressions are equivalent. For all other values they are not equivalent expressions. In C when an expression is being used as a boolean value (true/false) the numerical value of 0 is treated as false. All other numbers are treated as true. Aside: until recently C had no real boolean type. You can use the operator ! to invert a boolean value. So the expression ((!1) == 0) is always true, where as ((!0) == 1) is not necessarily true in all compilers, but is true in easyC. If you are treating "bumper" as a boolean value then the expressions: (!bumper) is a better test to check if bumper is false, and (bumper) is a better test to check if it is true instead of testing for equality against 0 and 1. These expressions clearly indicate that you wish to treat "bumper" as a boolean and you won't make any mistakes. Hint: Be very careful about not using a single "=" where you should have used a "==". The "=" will set the value of bumper to what you thought you were testing against instead of not changing it. Get into the habit of writing "if (3 == myValue) { ... }" instead of "if (myValue == 3) { ... }" that way if you miss the second "=" the compiler will generate an error instead of silently doing an assignment. Cheers! |
| C programming question | starchypizza | Programming | 2 | 18-11-2006 23:13 |
| Programming question | CircularLogic | FIRST Tech Challenge | 1 | 17-04-2006 21:52 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| C Programming Question | tophq | Programming | 7 | 16-02-2004 12:56 |
| Programming question | archiver | 2001 | 6 | 23-06-2002 22:57 |
