Go to Post No really though, a robot game with rules similar to Risk. This would combine FIRST, Battlebots, and US Government... - Betty_Krocker [more]
Unread 11-12-2008, 11:17
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
LV 2009 Dashboard
We've got our early 2009 control system. We've done the bench-top test, upgraded the Driver Station, LabVIEW and the cRIO. We've deployed the Basic project (set to run at start-up). That seems to work, we get the battery voltage readout on the DS. Before connecting our motors up, we wanted to verify the outputs via the dashboard. We connected our PC to the Driver station and the driver station to Ethernet port 1 on the cRio . We can connect with the cRio (deploy, etc). When we run the dashboard though, we do not get any updates. What are we missing? Is there a dashboard enable or something we are missing?
Thanks,
-Terry
-Terry Sherman
Team 93 Software Mentor since 2003
Unread 11-12-2008, 17:10
pgaston pgaston is offline
FRC #2103
pgaston is an unknown quantity at this point
Re: LV 2009 Dashboard
Stupid idea, but you do have both the dashboard project and the cRio project running at the same time?
Btw, we just got this running this afternoon - way, way cool when you see the camera work, the analog showing readings, the PWMs reacting - sweet!
Unread 11-12-2008, 17:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You need to have your PCs IP address set to .6
Unread 12-12-2008, 00:11
Mentor -- Software
I can get it to work if I deploy the FRC code to the cRio but not when I have it configured for start-up. When configured for start-up, the cRio code is running (communications with the DS and control of the motors works fine).
I've heard that there is a bug in the dashboard VIs, is that true? If so, what is the nature of the bug?
-Terry Sherman
Unread 12-12-2008, 12:11
Rookie Year: 1997
http://www.chiefdelphi.com/forums/sh...ad.php?t=70397 I have seen inconsistent results even without using the VI mentioned in that post.
I'd recommend not worrying too much about the dashboard until the LabVIEW update comes out. There should be plenty of other things to play with
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
dashboard archiver 2000 1 23-06-2002 23:06
Dashboard in VB archiver 2000 2 23-06-2002 22:49
Dashboard in C/C++ archiver 2000 0 23-06-2002 22:48
