Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Unread 11-12-2008, 23:15
finman's Avatar
finman finman is offline
Programmer
AKA: Chris Finley
FRC #0888 (Robotiators)
finman is an unknown quantity at this point
Bench Test Victor Problem
my team and i have carefully followed the instructions that came with the control system for a bench test. when we follow the directions and power it up, everything seems to be working correctly, except the victors are driving the motors, and begin to spark. we have double checked all of our connections and they seem to be correct. are we using bad victors? are the victors supposed to drive the motors when recieving no pwm signal at all? any other reason that we would be having this problem?
"Red goes to black, right guys?" ~Mike Mascaro: Our Fearless Leader
Unread 11-12-2008, 23:24
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Bench Test Victor Problem
Victors and Jaguars use different settings for their PWM signals - The Jaguars receive updates faster and with better resolution. A side effect of this is that driving a speed controller with the wrong settings can result in odd behavior. I can't remember which the bench top is set for, but I'd look there first.
What is sparking? DC brushed motors will often spark at their brushes, inside their case. What are you seeing?
Unread 12-12-2008, 06:33
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Be sure you have the latest version of the benchtop test procedures. They have changed. The latest version uses Jaguars, not Victors.
Former Mentor Team 1771
Former mentor Team 4509
Unread 12-12-2008, 08:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Chris,
The Victors will self destruct if you connect the power supply to the output terminals and the motor to the input terminals. A side effect of this mode is fireworks as the power FETs blow open and short. The electrical equivalent of measure twice cut once is check your wiring twice then apply power.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-12-2008, 22:16
finman's Avatar
Programmer
AKA: Chris Finley
thanks guys,
despite having checked my wiring job several times, in the process of moving the components from one board to another, a teamate of mine reversed the victors. he assured me multiple times that it was correct, but *sigh* there go two victors.
Unread 17-12-2008, 21:47
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Sorry to read of your loss. In the future, implement a checklist where 2 people have to sign off ( 4 eyes are better than 2- 8 with glasses!) before power is applied. These accidents can happen to the most experienced teams. Chualk on up to experience and go easy on the mistaken error.
Team MARS = 1.523 AU from the SUN!
Jim E.
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 problem Gal Longin Electrical 11 26-01-2005 00:47
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Victor Size Problem Jeff Waegelin Inventor 3 24-02-2003 15:35
Victor controller problem llambele Technical Discussion 3 14-11-2001 23:00
