Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 12-12-2008, 11:02
ZeroValue ZeroValue is offline
FRC #2122
ZeroValue will become famous soon enoughZeroValue will become famous soon enough
Dual spoke wheel
Instead of a one set of spokes in the middle of the wheel, I have half a set on each side of the wheel. Its still possible to machine it, one side is simply the pastern on the other side rotated thirty degrees. OD is 4" and the hex on the inside is 3/8" flat to flat.
pic: Dual Wheel Swerve-Drive =Martin=Taylor= Extra Discussion 5 28-04-2007 01:21
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
Bush spoke on FIRST Ryan M. Chit-Chat 15 01-11-2004 16:32
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
