Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Unread 21-09-2009, 15:54
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: CHEAP or EASY String Pots (source, or fabbed)
Originally Posted by kmcclary View Post
What is our project? This is a Fall R&D project. We wish to gain the capacity to accurately servo control a 24" sliding joint to say ~7-8 bits (or better) position resolution over its length (~4-10+ steps/inch) , with a cheap, easily made, compact feedback device.
If this is a prototype for possible FIRST use, I would say that +/- 1.0 inches is sufficiently accurate. If your actual design during season requires more than that, it won't be very human friendly.
Now, purely for R&D it's a cool idea, but don't think that such accuracy is always required. Your manipulator should be designed to allow substantial amounts of inaccuracy.
Unread 21-09-2009, 15:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Rack and pinion pots won't easily fit there, and optical slides could get dirty. Without a rotational joint present, cheap pots won't work either.
Something equivalent to a 25" string pot (into our Analog Inputs) seems ideal, but it:
A) Needs to be CHEAP to make (no $100 commercial string pots!), and
B) Preferably can be assembled MOSTLY with COTS hardware store items, with as little machining as possible.
Try a "chain pot". Instead of string, use a length of #25 chain. Think of a flexible rack & pinion connected to the end of your slide, with the chain bending around a pot-equipped sprocket and having a tensioning spring at the far end.
With a large enough sprocket, you might even be able to get away with a single-turn pot (or a magnetic absolute position sensor).
What are you using to move the slide? If it's a chain, you're most of the way there already.
Unread 21-09-2009, 16:53
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
I think you are missing the point here. This is not to solve a SPECIFIC design problem, it is For The Toolkit, as a Challenge... You can always DROP resolution for simpler needs, but it is much tougher task to INCREASE it.
Originally Posted by Alan Anderson View Post
Try a "chain pot". Instead of string, use a length of #25 chain. Think of a flexible rack & pinion [...] What are you using to move the slide? If it's a chain, you're most of the way there already.
Oooooohhh... Now THAT is an excellent idea, with potential! We'll have to look at that one! (See... I have faith in creativity of this community!)
BTW... What moves the slide, and the load are both irrelevant at this time. The challenge goal, as stated, is to make/develop/find a CHEAP and SIMPLE way to SENSE POSITION of a servo controlled 24" slide, and if at all possible, with the above spec'd resolution (or the best we can do, for the given $20-$25 budget). We can choose the app and a specific actuator later.
Because: A closed loop system is first off limited by the resolution of the feedback sensor/system. That is why we are shooting for what some here seem to feel is "excessive resolution". Given a "decent" resolution sensor, we can do ANYTHING. Once one knows where the slide is, LATER experiments can then test how EITHER cylinders OR motors actually perform, to move it around. (Which works better may well depend on the final app, load, and mounting orientation.)
Heck, if we can't REACH 0.1" resolution with the sensor that may be fine, but that is not a reason to never even TRY for it. Who knows? If can only hit 1" resolution for $20 per axis we are still WAY better off than before we tried, and we STILL have a new trick up our sleeve. (But I would bet if the team tries, it CAN do better than 1" resolution for $20 in sensing cost [discounting labor of course]...)
Any more cool ideas on making a cheap and simple feedback sensor, for 2' slide joints, for about $20, and using primarily COTS hardware store hardware??
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
A cheap source of pneumatic parts vivek16 Pneumatics 2 13-07-2008 21:46
Source code for the Easy C Pro library functions? bobpskier Programming 3 05-02-2007 21:39
Cheap small gear source archiver 2000 2 23-06-2002 22:33
