Go to Post How are you planning to teleport balls? Or your robot? I was pretty sure that the battery couldn't supply the required power draw. - RoboChair [more]
Unread 15-12-2008, 18:18
KilroyLaxer's Avatar
KilroyLaxer KilroyLaxer is offline
KilroyLaxer
AKA: Mike Kilroy
FRC #1033 (Holy Rollers)
KilroyLaxer is an unknown quantity at this point
Fusing for Digital Sidecar (was: HIZZELP)
is the fusing for the sidecar for the c-rio really 5 volts? or r we being lied to?
Unread 15-12-2008, 18:35
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: HIZZELP
Please try to be more descriptive in the thread name. This thread's title is completely unsearchable and is therefore of little use to other people who may need the answer to the same question.
Also, I have little idea what question you are asking. Please try to be more descriptive in your questions. I know that I know the answer to your question, I just don't know what the question is.
There is a good chance that I wrote the section of the manual you are referring to. I personally guarantee that I did not lie while writing those data-sheets.
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: HIZZELP
The side cars get wiring into the standard 12v breaker slot.
The 5v is for the Axis Camera....
Also Take Eric's Advice you might want to be more descriptive in your title and your question...
Descriptiveness always helps when asking questions on CD
Unread 15-12-2008, 19:23
Billfred's Avatar
Billfred Billfred is offline
Re: HIZZELP
While we're on the subject of forum norms and mores, I'm also moving this into the FRC Control System forum.
Unread 15-12-2008, 20:44
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
Team Role: Teacher
Rookie Year: 2000
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: Fusing for Digital Sidecar (was: HIZZELP)
I believe you are asking if we are supposed to use a 5 amp fuse (as written in the data sheet) with the Digital Sidecar. It has been posted on the FIRST forums that you can use a 20 amp fuse in its place.
I hope I helped & didn't make things worse.
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Missing Standoffs on Sidecar psyco_klown Electrical 3 03-12-2008 19:40
fusing ends of latex tubing Andrew Schuetze Technical Discussion 17 02-02-2006 16:16
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Looking for a Digital Camera AJ Quick Chit-Chat 7 02-03-2003 20:16
