Go to Post Rules arent built around robots. Robots are built around the rules. - dodar [more]
Unread 16-12-2008, 08:38
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Possible 40amp loads
Yesterday I recieved a the new wiring diagrams of the new controller system, to my surprise there are 8 40 amp breaker slots. As Newton once said Nature does nothing in vain, and neather do FIRST organizers. So the question comes down to will we use all of these 40 amp loads this year, and for what, or in the future, and then for what?
Is now an engineer thanks to FIRST.
Unread 16-12-2008, 11:47
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Possible 40amp loads
4 CIM and 2 FP motors gets you to 6 very quickly.
I don't have any idea if we will be getting more motors this year or next, but it makes sense for them to have designed a board that has the possibility of allowing more high current circuits in the future, rather than have to turn around and re-design it in a year or two.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 16-12-2008, 11:56
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
If the Mini-bike motors are ever brought back, there is another 2 40A gone.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 16-12-2008, 12:15
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I was just about to say that!
It would be really easy for the GDC KOP engineers to sneak another motor or two in that use 40 Amp breakers, provided they could get their hands on one. Think of it as future growth space.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-12-2008, 14:41
XXShadowXX's Avatar
They call me Cody.
It is more then likely true that they (FIRST org. people) gave us the multiple breakers for good use int eh future, the NI people at Atlanta mentioned that the controller shouldn't have to be replace for several years.
Most likely other items will be, the d-block has a 120 amp breaker between it and the battery, so most likely there won't be a ton of 40 amp drain this year. But in the future, i think we will get bigger batteries.
Unread 16-12-2008, 14:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Please remember that the 120 amp circuit breaker can withstand a 600% over load for several seconds without tripping. Although the battery is capable of 600 amps for a short period of time, it is wise to design for well below that current. The excess capacity is used during the stalled motor condition which takes place anytime the motor is not moving but power is applied. (i.e. starting)
Also keep in mind that the breaker protects the wire not the load. A 40 amp breaker is needed to protect #10 or #12 wire (or larger). A larger capacity battery in the same physical size would be nice but I would not expect a huge increase. Maybe move from 18 AH to a 19 or 20 AH.
Al
WB9UVJ
www.wildstang.org
________________________
Winch on 40amp breaker. 5dimes Control System 1 21-02-2005 08:20
Uneven Thrust Loads on Needle Roller Bearings Madison Technical Discussion 7 07-02-2004 01:00
extra 40amp wires Lord Nerdlinger Electrical 4 14-02-2003 14:53
Anyone Get Their 40amp Breakers!?!? Brian48216 Electrical 9 27-01-2003 22:48
