Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 17-12-2008, 19:28
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Team Role: Mechanical
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Exclamation Bunch o' questions about the new electronics layout
OK...our wiress is at work, and we need some help
questions:
1: 12-vold dedicated? what is that/where does it plug into the power distribution unit? we know the gaming adapter needs it...
2: 12-volt connectors for the I/O sidecars, do they plug into the similar looking plug on the power distributor, or do they plug into the wago ports?
we think they plug into a 30 amp breaker, but were not sure, since our data sheets dont specify.
3: WHAT IS WITH THE PWM CABLES THAT THEY GIVE YOU?
we cannot figure out how to take off the little plastic cover protecting the male end of the wire.
any strategies that dont include destroying the male end of the wire?
4: thats it...i thought there was more
thanks in advance,
~the two guys staying late after a meeting to finish this job
Unread 17-12-2008, 19:52
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
Team Role: Leadership
Rookie Year: 2007
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Re: Bunch o' questions about the new electronics layout
We just got our new system and considering it's finals week we haven't gotten to play with it yet, but I can tell you that as for your third question, you can refer to the following memo from FIRST: http://usfirst.org/uploadedFiles/Rel...ble%20Memo.pdf
Unread 17-12-2008, 19:54
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
This should help you see where all the power comes from and goes to: http://www.usfirst.org/uploadedFiles/2009%20Power%20distribution%20diargam.pdf
1: The white WAGO connector that plugs into the Power Distribution Panel is for the WiFi Bridge.
The grey WAGO connector that's built into the Power Distribution Panel is for the Axis camera.
2: The sidecars and bumpers use one of those white WAGO connectors on the boards themselves. The other end of those 12v lines connect to the Power Distribution Panel through the red/black WAGO connectors.
3: If you don't already have it: http://www.usfirst.org/uploadedFiles...ble%20Memo.pdf
4: Post again
Unread 17-12-2008, 20:54
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
If you haven't read the 5 chapters of the FRC Control system, you are setting yourself up for damaging the entire thing.
I would not want to be the one to go before my team and tell them I blew up the cRIO because I cannected a voltage wrong.
The above comments are a very good start, but they do not replace the importance of the 1st five chapters.
I had a lot of questions on this control system and found 99% of the answers in these chapters.
I am CET certified, and because of that, know the importance of studying new systems I'm unfamiliar with. It only takes micro-seconds to release the magic smoke and empty the teams' budget.
As far as the PWM cables, I found it quite easy to remove the protective shield by working small-pointed needle nose tips under the shield from the wire-side. There must be a locking tab there to release. It should slide it right off. If it's too hard from one side, turn it over and try the other side.
Don't forget to carefully remove the polarity-tabs on the other end.
Good luck in the 2009 season.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 17-12-2008, 20:40
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
There is a simple technique for removing the pin hoods from the PWM wires that is very quick and (almost) foolproof.
Grip the pin hood with needle-nose pliers or a Leatherman tool. Position the width of the hood between the jaws, near the base of the jaws. When properly positioned, it will look like you are squeezing the three PWM wires in to each other if you were to apply too much pressure - this is the correct orientation. Squeeze slowly and firmly (do this very slowly at first, until you get a feel for the right amount of pressure). As pressure is applied, the rectangular pin hood will suddenly crease and deform into a semi-hexagonal shape. Stop squeezing. At this point the hood has released, and can be pulled straight off the end of the cable with your fingers.
It takes longer to describe the procedure than to do it. Once you get the hang of it, you can remove the pin hood and free the cable in about three seconds.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Questions about the engines. yuval_bertocchi Rules/Strategy 1 24-01-2007 11:42
About the new rules-about the updated Rule <G09> aten Rules/Strategy 1 13-01-2007 13:20
Things that new members need to know about electronics Karma Electrical 10 20-11-2006 08:35
questions about the servos Alex Golec Motors 1 23-01-2005 20:05
New Brady Bunch Movie MattK Chit-Chat 3 30-11-2002 00:04
