Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 17-12-2008, 22:05
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Rookie Year: 2007
Straberrie will become famous soon enough
Pointers and Tank Drive?
Hi! I am trying to program a Tank drive and am using the programming guide for C++ as well as the Simple Template found in File - New - Example etc... in the Workbench.
In the programming guide, the Operator control code looks like this
void OperatorContol (void)
while (1)
drivetrain.Tank (&stick1, &stick2);
and well, the header included in the program is "WPILib.h"; I have the same header included and I have the variables defined exactly the way they are defined in the guide, but when I try to build the project, it states the following
:C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:31: error: `stick1' undeclared (first use this function):
How do pointers work?? In the guide, the joystick and pointer explanation is omitted *at least in the one I have, sorry if i skipped something*. So, is there anything I can read about pointers?? Or programming tank drive? Because I can't figure out whats wrong! *and yes, I am sorta kinda new to this, so if I made a silly error or am asking something stupid, sorry*
Thank you!!!!!!!!!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank drive Stormhammer Programming 11 29-01-2004 23:08
