Go to Post I don't think Dean Kamen ever recieved a real degree. That doesn't make him any less of an engineer.:) - Adam Y. [more]
Unread 20-12-2008, 01:00
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
Rookie Year: 2007
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
PrintFs
Does anyone know how to get window to see the C++ printfs coming from the robot on your computer? I have been able to download and debug code successfully but I am still unable to get feedback on what the code is actually doing other than the actions of the robot.
Unread 20-12-2008, 01:53
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: PrintFs
C++ printfs are known as couts. Try using a few of those.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-12-2008, 02:46
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: PrintFs
You need to configure your cRio and PC as described in section 5.4.1 of the control system manual. If you're looking for another terminal client for Windows PuTTY is what I'm using.
Essentially you need to use the serial port on the cRio for that type of output.
However if you're using printfs as your primary means for debugging I suggest you look into using break points and the other debugging tools integrated with windriver.
printfs work as expected when you configure your system as I said above.
Eric Haskins KC9JVH
Robot not doing what we need it to, and printfs aren't working Bryan Herbst Programming 8 21-09-2008 20:58
