Go to Post Mike Wade was the Fall offseason guy. - Michael Leicht [more]
Unread 20-12-2008, 18:32
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
pic: Another Cheap Wood Frame Idea
Unread 20-12-2008, 18:35
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Rookie Year: 2000
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: pic: Another Cheap Wood Frame Idea
You might want to consider dovetail joints and internal corner blocks instead of gussets. The cost is about the same and the cornet blocks are much stronger.
Good luck with it.
Unread 20-12-2008, 19:28
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We were discussing corner blocks, pretty easy to add them.
Gary and Steve and I spent an hour today at the fab shop and made this...
and the all important weight:
Unread 20-12-2008, 19:32
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
have you checked to see how much flexing there is?
is that oak?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 20-12-2008, 19:35
MrForbes's Avatar
AKA: Jim
Still waiting for the glue to dry completely....the sides and ends are 3/4 Birch plywood, the base and gussets are 7/32 normal cheap plywood. $20 of wood in this thing.
Unread 20-12-2008, 20:37
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
you could fiberglass it(at least the base and corners if not the whole thing)
although its messy, i like using fiberglass, you can take wood, and make it very strong, and stiff
Adam Spears
Unread 21-12-2008, 02:00
CraigHickman
Posts: n/a
And brittle.
Unread 21-12-2008, 09:58
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
If you intend to fiberglass anything and I mean anything I suggest you stay far away from the cheap polyester(automotive) resin and hardner and only use epoxy resins. Epoxy is a MUCH better adhesive than polyester resin. If properly prepaired it WILL NOT let go of most any material it gets on. I have built an entire 20 foot fishing boat from plywood and WEST system epoxy. I have been in some pretty ugly weather hopping 6 foot waves with it and I still haven't drowned. It is more expensive than polyester resin but you get what you pay for and you are not going to use a lot of it anyway. Don't cheap out here. Go to www.westsystem.com for all the information you will need. No, I am not affiliated with them but I am a true believer.
Bruce
Unread 21-12-2008, 10:54
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
Originally Posted by CraigHickman View Post
And brittle.
in my expeireance with it, fiberglass only becomes brittle if you dont mix the resin right, or wait to long to apply it,
they switched to epoxy resin in surfboards because, polyester resin dosent stick to the new type of foam most companies use.
you dont even have to use the fiberglass mat, you could just take a paintbrush and dip it in the resin and "paint" it around the corners and edges
we're getting off topic now.......
Adam Spears
Unread 21-12-2008, 11:33
GUI GUI is offline
AKA: Gary
In the past our chassis has been made of pultruded fiberglass and worked great, but it was a bit messy, and murdered drill bits and saw blades (we finally figured out that it should be cut with an abrasive blade in a chop saw, whic is veeeery messy). The idea for this chassis is to be cheap and easy to build. Wood has similar properties to the pultruded fiberglass, but is easier to work with, extremely cheap, and available locally.
Unread 21-12-2008, 11:48
MrForbes's Avatar
AKA: Jim
The wood chassis by itself seems to be plenty strong and stiff, and like I said before it took us an hour to build it, and cost $20 for the materials.
If you think it could use improvement, I suggest you build one yourself, and see where the weaknesses are, and let us know how to make it better! After all, it only costs $20 and an hour of labor. (yes, I'm making a big assumption, that you have the machinery necessary to build it....but that is mostly the same machinery that has been required to build bumpers the past two years)
Unread 21-12-2008, 11:53
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You might want to put on a "marketing hat" as you talk with people about this, or similar ideas -
Instead of a "Cheap Wood Frame", maybe a "Low Cost Wood Frame" or an "Inexpensive Wood Frame" or a "High Value Wood Frame".
The word "cheap" can imply junky, low value, and turn people away - when I think you really mean it is Low Cost..
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 21-12-2008, 12:22
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
could you tell us the dimensions?
ill see if i can get to home depot today or tomorrow
did you apply the glue then staple it?
luckily gorrilla glue is cheap
Adam Spears
Another electical setup idea from my team fo 08... cdennisxlx2 Electrical 13 11-10-2007 13:47
Another idea for future competitions archiver 2001 13 24-06-2002 03:33
Another Idea of Expanding the Nationals archiver 2001 2 24-06-2002 03:28
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
