Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 20-12-2008, 21:13
knine143 knine143 is offline
FRC #1047
knine143 is on a distinguished road
"Battery: No Code" after uploading .out file to cRIO
I successful compile the SimpleTemplate and upload the .out file to the cRIO using the Wind River Workbench and the FIRST downloader inside the workbench. However, after restarting the cRIO, my program does not run and the driver station displays "Battery: No Code". What's going on?
Thanks for your help.
Team Echoes: teamechoes.com
Robots on the site: Hexapod, Zippy autonomous robomagellan 1st place winner, FIRST robots
Unread 20-12-2008, 22:14
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: "Battery: No Code" after uploading .out file to cRIO
Did you create a stand alone application from the template? If not, you will have to upload it each time you turn off the cRIO.
check under Project explorer, right click Build specification and select standalone application. This is from memory, folks can correct me if i'm wrong.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
On compile: "Coff file format for 'ifi_library.o' is out of date." Ethulin Programming 11 17-01-2007 18:03
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
HEY!! Time to get ready for "after-glow"! skrussel Off-Season Events 5 24-04-2003 23:02
