what is the gyro sensitivity?
and how can i measure it?
I am using WPILIB library, so if you will write some code it would be more comfortable for understanding, thanks. |
Re: what is the gyro sensitivity?
You should get it from the data sheet of the gyro you are using. It's the number of volts change in the sensor reading for every degree per second rotation rate.
| ADXRS150 Gyro Yaw Sensor sensitivity? | hinewwiner | Technical Discussion | 5 | 08-02-2008 09:20 |
| controller sensitivity | kDude | Programming | 5 | 06-02-2008 16:22 |
| controller sensitivity | kDude | Programming | 0 | 06-02-2008 15:42 |
| Joystick sensitivity | Philz20 | Programming | 10 | 24-01-2008 08:34 |
| joystick sensitivity | Team 668 | Programming | 11 | 16-02-2005 18:45 |
