Go to Post I have some free time tonight (What?) - Brandon Martus [more]
Unread 23-12-2008, 23:34
jalburty jalburty is offline
Joe Alburty
AKA: Joe Alburty
FRC #1763 (Paseo Pirates)
jalburty will become famous soon enoughjalburty will become famous soon enough
Send a message via ICQ to jalburty
Wireless problem - losing communication
When using the joysticks to operate under a wireless connection we are consistently losing communication with the robot whenever suddenly going from full forward to reverse. It happens in arcade mode or in tank mode (only one joystick going from full forward to reverse in tank mode does not cause the problem). The robot then comes to a stop with the LEDs flashing on all four Victors indicating no signal and the driver station indicates no communication.
-We can regain communication by switching the driver station to disabled and then back to enabled and waiting about a minute.
-The problem happens just at the point when the motors start to reverse.
-The problem happens with the robot either up on blocks or not and we have checked our electrical contacts very carefully.
-The robot works fine in tethered mode.
-The problem does not happen if we go from forward to reverse slowly and gently.
-We are using the C++ version of the default code.
-We are using four Victor 884 motor controllers.
I suspect either the wireless router or the wireless bridge is the problem. Perhaps too much data is being generated by the joysticks for the wireless link to handle. The problem occurs only when going from full forward to reverse somewhat suddenly so we are able to get along for now, but this must not happen during competition.
Anybody else witnessed this behavior?
Joe Alburty
Team 1763
losing air pressure razor95kds Pneumatics 3 13-02-2007 07:17
Wireless communication during the matches dwc309 Control System 10 11-02-2006 11:04
Highest Losing Score Ben Piecuch General Forum 9 03-04-2005 23:17
