Go to Post The point of FIRST is to get a wide range of kids together and have them work as a TEAM. - Firewolf [more]
Unread 24-12-2008, 05:45
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
Limit switches(in C++)
how to get the value of the limit switch(pressed or not) through c++ wpilib? thanks.
Unread 24-12-2008, 09:16
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Limit switches(in C++)
What is this limit switch connected to? A digital input or a jaguar?
Unread 24-12-2008, 14:59
None #2669
DIGITAL
Unread 24-12-2008, 15:27
Check out DigitalInput.h
Code:
DigitalInput *limitswitch = new DigitalInput(x); <- x is the DI location
limitswitch->Get();
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
Alternative to limit switches? RbtGal1351 Electrical 27 10-12-2005 15:30
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Limit switches Team168 Programming 8 10-02-2003 16:22
