pic: my version of a wooden chassis
Re: pic: my version of a wooden chassis
31.2 lbs???
We've never used the kitbot frame, but it just seems entirely implausible that the bare kitbot chassis could weigh more than that. Maybe with gearboxes, chains, motors, and wheels? |
I think that's right Cory, the kitbot chassis with transmissions, wheels, and motors would weigh about 30 lbs.
gorilla, I'm curious why you made it of such thick wood? |
its supposed to be 21.2 (i did my math wrong)i used the 2x6's because 3/4inch plywood in florida is $32 and I was thinking about using a bearing block as well as a ball bearing in the wood itself for the canitleverd wheels also i wanted to be able to use screws as well as the liquid nails....... i figured the extra weight was worth it and i wanted to be able to just bolt our supershifters to the wood also Last edited by gorrilla : 24-12-2008 at 14:35. |
We found precut 1/4 sheets (2 feet x 4 feet) of 3/4" birch (cabinet) plywood at 3 different building supply places for about $14-$18. Sutherlands, Lowes and Home Depot have it in stock.
thats what i used for the bottom... i had a discussion about that with my team, and we thought it would be better to have thicker sides if we were going to use cantileverd axles what i could have done, is just had the 2x6's for the sides, and the plywood for the ends and bottom..... |
If your frame right there weighs 21.2 lbs, you're going to have a significantly heavier base than if you used the kitbot, not lighter.
not really, the kitbot after we put the four cims and two supershifters and all the electronics and chains and (IFI)wheels was just about 36 pounds, with the wooden frame, im planning on using directely driven (AM)wheels and only two chains, the BB transmission should work nicely, im still deciding weather we should use the supershifters or the banebots(i think this is were the weight could be made up ot lost), its really all a matter of what we want to use if for(probobly just for testing and demos) i still think it will be lighter(even if its only by a pound ill be happy) Last edited by gorrilla : 24-12-2008 at 15:16. |
That's going to be a seriously strong chassis. Once you get all your components mounted, get yourself a 2" spade bit and whack some speed holes down the center line of those 2x6s. Remember, the stiffness of a beam goes up as the fourth power of its cross-section. 2x6 studs are really, really stiff on edge -- and the breaking point is also very high. You can easily remove material without compromising strength below a danger point. That 3/4 ply is heavy, too. Do you have a piece of 1/2" you can use? You really don't need that 3/4.
On the other hand, a cheap, strong chassis. Have fun! |
#10
Home-depot was out of 1/2 inch 1/4 sheets.......(would probobly save a pound or two without compromising strength) thats really what i was going for with the wood, its going to be 6wd if we have enough of the AM wheels left it is really strong, i dropped it, kicked it, jumped on it , stood on it, and hit it with a hammer repetedly(and im not a small person) the only thing im concerned about is taking an hit on the side, and cracking the 2x6(but there will be bupers so it shouldent be that big of a problem)...... oh and interestingly, i think the bottom panel added a lot of stiffness, before i had it on, it would kinda flex out a litle bit Last edited by gorrilla : 24-12-2008 at 15:40. |
#11
If you can get some 1/4" and 3/4" plywood, I strongly suggest you build one similar to ours and see how you like it...you might be surprised how strong and light it is. Last edited by MrForbes : 24-12-2008 at 17:58. |
#12
- Rick Last edited by Rick TYler : 24-12-2008 at 21:53. |
#13
21.2 lbs chassis + 9.2 lbs Supershifters (as is, without any lightening) +11.0 lbs CIMs + 4.0 lbs 6 AM Plaction wheels = 45.4 lbs That is with no electronics, and no chains. You'd have to remove a ton of material for that to come in anywhere near 36 lbs. |
#14
I meant the AM kit wheels, and I might use BB transmissions, and we only have two cims extra currently so it might be just 4wd for now.... the electronics shouldent be more than 8 pounds for it |
#15
The cRIO alone is nearly 5 lbs. I would definitely budget more than 8 lbs.
| pic: Wooden Rack | Wetzel | Extra Discussion | 3 | 07-01-2007 16:33 |
| pic: Wooden Rack - Center | ebmonon36 | Extra Discussion | 2 | 07-01-2007 06:26 |
| pic: Wooden Wheel | Elgin Clock | Extra Discussion | 13 | 10-05-2006 09:13 |
| pic: Wooden Robot | LetsGo810 | Robot Showcase | 9 | 27-02-2006 13:39 |
| pic: Wooden Thunder, Team 1294 | Rick TYler | Robot Showcase | 11 | 23-02-2005 21:40 |
