| Thread Tools |
Rating:
Display Modes |
i have a problem with line follower
hey ...
I downloaded the easyC code for the line follower to the vex ... but it doesn't work ... only the joystick worked well .... and when i click on chanel 5 it change to atanumous mode but the robot doesn't follow the black line here is the code i am using http://www.vexforum.com/local_links_...=line_follower i want to say that i downloaded the code by easyC pro .... but i read that this code only work in easyC V2 is that true ?? please give me the answer and don't late |
Re: i have a problem with line follower
| [OCCRA]: OCCRA 2008 Line Follower - Program 2 | marccenter | OCCRA Programming | 0 | 27-09-2008 00:27 |
| [OCCRA]: OCCRA 2008 Line Follower - Program 1 | marccenter | OCCRA Programming | 0 | 18-09-2008 11:32 |
| Help With Line Follower | computerwiz514 | Programming | 3 | 24-06-2008 13:35 |
| Do you have a problem with the IR Board? | DonRotolo | Control System | 5 | 07-01-2008 23:57 |
| Vex line follower sensor kit program | jbill30 | Programming | 5 | 12-05-2006 14:43 |
