Go to Post Bless you sire and all your HD camera goodness. - pyroslev [more]
Unread 12-28-2008, 04:03 PM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Why is weight so important?
This will be our fourth build season, but I've only been utilizing chief delphi and other resources over the last several months. I'm curious about something that seems to come up frequently in technical discussions: weight. Why are there so many individuals and/or teams concerned with having the minimum weight on their robot and parts (some recent threads on wheels that weigh less than a 10th of a pound would be a case in point)? Of course, I understand the need to remain under the limits (our bot had to be drilled at the last minute to make the weight requirements last year), but really, once you're under a certain maximum, what's the point? Is it just something to add to the challenge from an engineering perspective? Is it bragging rights? Are their special awards/categories that I'm unaware of in my ignorance of FIRST culture? I appreciate any enlightenment you are willing to bestow.
Unread 12-28-2008, 04:08 PM
Re: Why is weight so important?
Team's sometimes like to keep their weight to as light as they can get, while still being structurally sound, in order to give them leeway when adding on components and other parts at regionals. There's also the case of weight distribution on a certain type of robot. Teams spread their weight evenly or lopsided in order to maintain CG and while building their robots they keep this in mind.
Unread 12-28-2008, 04:18 PM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
The vast majority of FRC robots are right at or very close to max weight. Any weight that you can shave off one part (gearbox, chassis, etc.) is weight that can be used to add functionality or additional strength to the parts of the robot that you feel need it more.
Unread 12-28-2008, 04:25 PM
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Its alot like Backpacking, if it takes cutting off the handle of a toothbrush to make it work, then so be it!!!
Unread 12-28-2008, 04:32 PM
BrentJ BrentJ is offline
BrentJ has a spectacular aura aboutBrentJ has a spectacular aura about
Smile Re: Why is weight so important?
It can also be a weight / power trade off.
Eg to get a robot moving at the same speed at different weights takes different amounts of motor power. By making the robot lighter you may be able to use lower power ( cheaper ) motors.
Also if the motor doesn't have to generate as much force ( torque ) to move the robots then you use less electrical energy from the battery. So the battery charge lasts longer or you can use that energy somewhere else like a stronger / faster motor for the arm.
Materials is also another area where you can save money.
To keep it simple I'll use an example of castors.
Say you have 100lb robot on 4 castors. So say you decided you need 25lb castors ( 4 * 25 = 100lb) to spread the weight ( we're ignoring a lot of things to keep this simple ) and they cost $10 each = $40. But you lighten the robot to 80lbs now you could use 20lb castors at $8 each = $32 a saving of $8. Not much of saving but every bit counts.
Also a lighter robot means you can ship more spares / tools in your crate.
I know this is an over simplification but I hope it gives you the idea.
It's a matter of balancing everything out.
Like you wouldn't try and tow a caravan over the Rockies with a British Mini car. In the same way you wouldn't use a Kenworth truck to tow one of those luggage trailers you see towed behind mini vans.
Unread 12-28-2008, 04:39 PM
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
There are many reasons to keep the weight of structural components as low as possible.
First of all is the aesthetic argument that a strong, lightweight piece is simply more elegant and better thought out than a needlessly heavy piece. This isn't the most convincing argument, but in a contest that focuses on engineering design I believe it is relevant.
On a more practical basis, by building structural components light, you can have more of them... this means that you can get your robot to do more things. For instance if you can shave a couple pounds off your frame, then you can perhaps add an extra motor or manipulator component.
Designing with a focus on weight also prevents last-minute robot diets... I've seen teams have to shed as much as 30 pounds on a Thursday at competition, but in our experience it mostly comes at the end of build where we need to re-inforce or replace one system or component, but don't have room in the weight limit. So we break out the hole saws and start lightening the robot elsewhere. Now we try to design the parts lightweight right from the beginning as it is much easier to shed weight at the design stage than at the "oh sh.." stage.
Building light also allows for changes to components at (or between) competitions... or repairs that aren't as light as the original part. At GTR one year a major component broke and we fabricated a heavier replacement part. Going in to elims we weighed 120.0 lbs. Had we not taken the time to replace the steel machine screws holding the electrical components to our robot with nylon screws two months earlier during build we wouldn't have been able to compete on Saturday afternoon.
Finally, even if you can build absolutely everything you want in to your robot, come out ridiculously under the weight limit, with lots of room for upgrades and repairs, you can improve the performance of your robot by building lighter still. It gives you the choice of either having lower mass for higher accelleration (F=ma applies here too) or adding ballast to lower your centre of gravity and/or improve traction and handling.
Jason
Unread 12-28-2008, 04:55 PM
Francis-134's Avatar
Francis-134 Francis-134 is online now
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
This long and the short of it is that the lighter your robot is, the more stuff (or the more complex stuff) you can put on it. While saving, say 1/2 pound isnt much, doing it three or four times in a few different places can make a huge difference. Most importantly, 1/2 pound may mean nothing if your robot weighs 115 pounds, but makes a huge difference if it is already at 120.
As stated before, a lighter robot we be able to accelerate faster than a heavier robot, which can be very important in certian circumstances (rabbit robots this year is a perfect example).
I'm somewhat fond of saying, if your robot dosen't weigh 119.99 pounds, you forgot something.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 12-28-2008, 05:03 PM
CraigHickman
Posts: n/a
For me, I design all moving parts to be as light as possible, and all fixed parts to try and hit the sweet spot between strength and weight. Lighter moving parts = less force required to get them moving = faster acceleration. Speed = win.
Unread 12-28-2008, 05:23 PM
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Because the new control system weights as much as a fully-loaded M1 Abrams Tank.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 12-28-2008, 05:25 PM
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Oh my... so does that mean we such do tank track drive setup to squish the red fishy? Hmm.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 12-28-2008, 05:35 PM
You're some kind of a math genius, Craig.
Unread 12-28-2008, 05:43 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
In the several responses to your question, no one has yet directly answered some of your questions
Originally Posted by mrnoble View Post
... Is it just something to add to the challenge from an engineering perspective?
No - It is the result, not the source of the challenges.
... Is it bragging rights?
Sometimes - For some people this topic does become their harmless obsession ... Other folks find other ways to improve designs.
... Are their special awards/categories that I'm unaware of in my ignorance of FIRST culture?
No; but all other things being equal, lighter is usually better (and can be pointed out when the obvious awards are being sought).
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 12-28-2008, 05:54 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I view weight as a limited resource on the robot, you can only have so much of it.
If you could buy drive gearboxes that worked great, were reliable, and fit your application perfectly for $100, why pay $200 for something that does the same thing? I feel the same way about weight, if you can cut weight WITHOUT killing reliability (which should be obvious, you should be making parts strong enough regardless), I see no reason not to.
Being lightweight in component design allows you many benefits; you can fit more on a robot as it all weighs less, you can keep the robot weight light for better driving & decreased battery use, and you can make up that weight with ballast real, real low on your robot to put the CG exactly where you want it.
I've seen a recent trend on CD that many people feel that removing weight through machining operations is unnecessary, and even a foolish waste of resources. It is a worthwhile operation, and doesn't even *need* to be a CNC'd accurate operation, much of the cosmetic pocketing you see on gearboxes with fancy curves and such can be approximate with a manual mill (if you know integrals, imagine you're approximating the pocket with a bunch of rectangles X units wide. X being an endmill small enough for a decent amount of material to be removed, but large enough as to not take forever). You can even draw the pattern you'd like, and drill or dremel material out; just don't take more material out than you designed in the drawing.
Before trying to machine weight out, assuming your fabrication resources are limited, you should consider thinner and lighter materials or just try to make parts smaller overall.
Unread 12-28-2008, 06:23 PM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
As mentioned, weight is an issue with the new control system being about 3 times heavier than the old one. Generally speaking, teams have a hard time staying in the legal weight limit with a bare minimum running much less. Last year I had one or two teams that weighed in at less than 90 lbs. with the bumpers. I had one team weigh in at 143 lbs. due in part to a faulty scale at their shop. Note to self...test the scale using last year's robot with the battery out to be sure.
Al
WB9UVJ
www.wildstang.org
________________________
  #15   Spotlight this post!
Unread 12-28-2008, 07:32 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Weight is definitely very important. There are different ways of dealing with weight, though. If you start out with a realistic weight budget for different parts of the robot, and revise the design as needed to meet that budget, then you might be able to get away without having to do any "weight removal" machining at all. We did this last year, our robot was pretty big and capable and weighed 10 lbs under the limit.
There are some folks who seem to get carried away with making everything as light as possible, and they probably have a great future in the aerospace industry. Others don't really worry too much about spending any extra time making things light, and they probably have a great future in the consumer goods industry.
Weight? Estmate weight? Arkorobotics General Forum 21 01-29-2007 05:34 PM
Why FIRST is important... Joe Johnson General Forum 7 05-23-2006 02:22 PM
pic: Why 12 m/s is important. Kris Verdeyen Extra Discussion 15 02-22-2006 06:01 PM
Wait...weight...weight!!!! Greg Perkins General Forum 3 02-22-2006 07:42 AM
Weight Michael Leicht General Forum 43 01-16-2005 10:09 AM
