Go to Post We do have a good time. Mr. Bill - Bill Beatty [more]
Unread 30-12-2008, 09:16
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Best way to detect a bot
I was wonder what sensors everyone has used in the past to detect other bots. It would be great for auton if our bot could detect the crashed bot infront of it and not add to the pile (I'm not trying to offned anyone, but accidents always happen). I don't want to use the camera because of the high overhead. Here are some thought I had.
Heat signurtes of other bots (not sure if the are high enough, though)
Electric or magnetic field sensors
Transducer array
Vibration meter (see if there are vibrations different from my own)
Would like an infared or radio reaper, but that is illegal
Could we use the gaming adapter to sense the strength of other bot's adapters and use that to tell when we are close?
I just want to see how others have done it.
Unread 30-12-2008, 09:46
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Re: Best way to detect a bot
I think an ultrasonic sensor combined with dead reckoning and pre-programmed knowledge of the field would do the trick. However, you don't want to get too cautious: if a game piece falls in front of you, you don't want to waste your time driving around it (unless they are heavy). I know there were robots (specifically lap bots) that could drive around traffic in autonomous mode last year.
Another idea I've had in the past was a microphone or microphone array, but being passive sensors, they would not work to detect a robot that has crashed and is just sitting there stalling its motors. They'd be more effective as a defensive autonomous mode, hunting out opposing robots and bumping them.
Other less-active options are to have a bunch of routes or delays that you can select from before the match to give maximum flexibility. If your alliance partners can only take a certain route, then delaying for a few seconds before starting your own autonomous might give them time to get out of the way. This can be achieved with banks of switches and potentiometers on the side of your robot, allowing for the run-time selection of varied modes.
Unread 30-12-2008, 11:13
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
One of my pipedreams is to use one of Cypress's PSoCs as a capacitive sensor to detect robots. They claim they can detect a person at a distance of one foot using a stub of wire, but I bet you could optimize further and get some interesting results.
Unread 30-12-2008, 12:28
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
In my order of preference,
Radar, camera, ultrasonic. Magnetic sensors will be confused by rebar in the floor of most competition sites, heat will not have built up to a detectable level during auton, RF levels at such short distances will likely not give adequate collision avoidance.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-12-2008, 14:03
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Don't forget touch sensors... they aren't as exciting, but they ARE simple, cheap and reliable. Consider, for instance, the HexBug.
Jason
Unread 30-12-2008, 18:58
FRC #1178 (DURT)
I didn't want to use touch sensors because you have to actually touch the bot to know if one is triggered. That cap idea sounds very interesting. I like plyaing with radios, so I know how much difference a foot from the radio improves reception. Give me an hour or two, and I can probably have a schmatic up.
Unread 30-12-2008, 20:21
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
IR sensors played a huge role in the most satisfying FRC match I've ever had the pleasure of participating in. I've even got the video to prove it!
In autonomous mode of this match we (the robot with the red bumpers) picked up another robot with those Sharp IR distance sensors. I'm pretty sure that's the exact model we used on that robot. Either way, I've used a few of the models and in my experience they work equally well. They were statically mounted, we turned the robot. We've experimented with mounting them on servos, but as always, we run out of time. A word of caution though, IR sensors will not see polycarbonate (Lexan) unless they are pointing directly at it (the "beam" is perpendicular to the Lexan). They also are not very reliable at seeing particularly shiny things (think polished diamond plate commonly found on FRC field). Those are our experiences anyways!
We've experimented with the MaxSonar sensors. Those also work well.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 30-12-2008, 21:49
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Who said you'll WANT to avoid other robots in auto mode this year? (Look at, say, 2006, 2007, 2004, 2003...)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 30-12-2008, 22:27
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Hey! I have experience here!
Our 2008 (international rockwell automation award winning (couldn't help it)) control system had this feature until the sensors caught fire at the Midwest regional. It worked great, but we never replaced the sensors.
I took it a little further than just stopping though. Our control system allowed for distance/bearing waypoints and arc commands, so the distance data from an array of 2 ultrasonic sensors on the front of the robot (after being washed through a continuous averager and rejection filter to get rid of individual sample point noise characteristic of vibrating ultrasonic sensors) was used as a 'floating' waypoint. This allowed the lower level acceleration/deceleration/velocity control layer to handle a smooth deceleration to a stop at a specified minimum distance from an object ahead (I had it at 36" since the sensor might be looking at something inside the robot ahead). The cool (unexpected) bonus? If the object approached the robot... the robot backed up to hold it's distance. And, though it never occured in competition, since the waypoint handling layer sat where it was in the control structure, the robot could keep track of it's position and reverse-interpolate an arc if that was the command it was currently executing.
Great feature to add. I highly suggest you add at least a little bang bang control loop to hold distance from an object as you approach... since then you can badge your robot as having adaptive cruise control! (ooooh! )
-q
p.s. to get back on topic, use ultrasonic sensors
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 31-12-2008, 13:27
FRC #1178 (DURT)
First off, someone told me last year that IR, Ultrasonic, and radio sensors were illegal because they emit waves (first year for me, so I believed him). Secondly, I got a sensor book for Christmas and it had a schmatic similiar to this one.
Notes (This was the first time I used this program)
The transistor is a MPF102 FET
The loop antena is actuall just a plate or wire
The volt meter is an amp meter
The electroscope is designed to sense changes in the electric field around the object. If a robot got closer, the field would change, right?
Unread 31-12-2008, 14:12
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
While that circuit will detect changes in the EM field, it may not do what you want.
First, the number of windings in the antenna, length of the antenna, and the values of the RC circuit (coupling) behind the antenna will affect the efficiency of the antenna and center frequency.
The other issue you'll face is filtering out the changing EM from your own machine. Your motors (Being closer to your antenna than any other robots motors) will greatly affect (possibly even completely washout) your ability to see another robots EM field.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 31-12-2008, 14:42
FRC #1178 (DURT)
What if I used an shielded antena? What I mean is what if the antena was shielded in the direction of my own motors. Also, I could take measuements before hand and figure out what level the EM is at when all motors on the bot ar running and use the code to filter them out.
Unread 31-12-2008, 17:16
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Something tells me that the changing EM of the other robots will make that worthless. I don't know much about this, but if the changing EM from your own motors is enough to wash out the antenna, then you aren't going to be able to judge distance to other robots for the same reasons. The robot may be stopped, or the motors might be spinning at full power giving different EM readings regardless of where the other robot actually is.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 31-12-2008, 17:54
FRC #1178 (DURT)
I guess you guys are right. It still sounds like a cool idea, though. I guess I will stick to ultrasonics and IR like everyone else.
  #15   Spotlight this post!
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The only way I know that would shield your antenna (without interfering with its function) is to put a Faraday (sp?) cage around your motors which would affect their efficiency.
Also, Mr Freeman is correct that while you may be able to detect another robot by its EM emissions, judging its distance by field strength is probably not going to be effective/possible.
___________________
- Tennyson, Ulysses
Best Way to Get Points SSMike Rules/Strategy 54 09-01-2008 16:46
Reliable way to detect disconnected controller heydowns Control System 4 13-02-2007 08:30
Best way to start Torboticsmember Programming 4 06-02-2007 12:27
Best way to make money! SPDEXL Fundraising 17 21-07-2003 01:19
What is the best way to learn? Tton 3D Animation and Competition 7 25-03-2003 19:22
