pic: 6wd prototype chassis
Re: pic: 6wd prototype chassis
What is the total weight on that?
I think 1/4in plate is overkill, but I will let others who have more experience comment on your design. |
I would have to add in that it seems that you have enough capabilities to machine out your own 2spd gearbox if you wanted to. They would end up being a lot lighter than the SS. Idk how the lightening pattern would hold up but how about 1/8" side plates? You'd still be adding bumpers (if that rule still applies for 09). Try to spread the battery and compressor weight in the back more unless the game calls for lumping their weight together in one corner like Overdrive did for many teams. |
5/8" sounds like overkill for me for dead axles. I would probably recommend 3/8" for that situation.
Just looking at that design, 7 sprockets per side of the drivetrain, with one direct driven wheel, looks way overkill. I'm not quite sure on the function of the extra four, but it appears to be some sort of elaborate chain run in order to use one chain per side. I would recommend using two chains per side with a double sprocket in the middle; one chain run from the front wheel to the center wheel, another from the center wheel to the rear wheel. This makes the chain runs nice and simple, as seen here. 1/4" plate sounds like overkill, but in this situation, it could be necessary to use [relatively] thick sheet metal to maintain rigidity in the chassis. If you have the capability, you might consider adding flanges, as seen in these photos. This would certainly make your chassis rigid enough to use thinner plate. |
Looks pretty nice the one thing I can tell you is that 3/16" is adequete for the side plates. That's what we've done for a few years.
The only thing I'm missing is how will adjust chain tension with this design? |
I'm not familiar with adding flanges, and I don't know if we have the capability of machining it. If we used 1/8" or 3/16" aluminum, would it be necessary to add flanges to ensure rigidity in the frame? If so, what size would they need to be? |
The Performance wheels or Plaction wheels are both narrower and have a 1.125 diameter bearing bore (bearing bore Performance wheel is a separate option from hex bore). You can use 1/2" or 3/8"ID bearings in these holes (The performance wheel is provided with 1/2" ID bearings). |
Is there some reason you are set on a 6 wheel drive?
The simplest drive to build and maintain and program is a two wheel drive like the zero radius turn lawn mowers. You simply drive the two rear wheels and put pivoting casters on for front wheels. We do not know what this years competition is but if you have to go up a ramp or hill at an angle the two wheel drive allows for a suspension which is difficult to achieve with the 6 wheel tank drive. Just my thoughts Good luck |
| pic: FRC1293 Prototype 6wd Chassis | Thermal | Extra Discussion | 16 | 01-06-2009 11:12 PM |
| pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis | artdutra04 | Extra Discussion | 14 | 01-02-2009 02:11 AM |
| pic: 6wd chassis - need feedback | JHSmentor | Extra Discussion | 22 | 01-01-2009 02:20 PM |
| pic: 6wd chassis | spc295 | Extra Discussion | 21 | 11-10-2008 09:00 AM |
| pic: 226 Off-Season Prototype Chassis | Matt Reiland | Robot Showcase | 2 | 02-01-2005 07:33 PM |
