Re: How can we drive on this new floor?
One thing to watch for when designing the robot is turning ability when using skid steering (tank drive).
If you notice the coefficients of friction for the wheels, you will see that inline dynamic is .05 while transverse dynamic is .10. In a skidding situation the wheel will be twice as resistant to going sideways as it is to going forwards.... That means, as I read it, that your wheel is not going to want to slide sideways very easily if you use 4wd tank drive. In fact anyone planning on going with skid steering will probably want to really look at using at least six wheels to minimize the amount of skidding required in a turn. Jason |
We bought two 4' x 8' sheets of that "ice" material ($30 per sheet) for the floor and did some testing. We compared traction on the "ice" the carpet and plain old tiled floor. The ice was the slickest. The carpet was slick but not as bad. The tile was surprisingly almost the same as the ice. So, to answer your question, if you cannot afford to buy some of the ice material, use a tiled floor as your best simulation.
I was thinking that we might stretch a large sheet of plastic over a tile floor and tape down the edges. If the plastic is thick enough, hopefully the robot will not wrinkle and tear it long enough to practice. |
So does anyone want to chime in about using these wheels as omniwheels. Would it even be possible. I am feeling slightly lost since all of my preseason designs involved mega-traction and multi-speed high torque transmissions
These wheels, according to the manual, have a transverse coefficient of friction that is about twice that of the inline direction. They are, by my reading... anti-omni wheels. Jason |
could you find this and link to it? |
It seems to me that heavier Bots will do a lot better, and I'm sure everyone will be maxed out on weight, so the question is how do you add weight....without adding weight....
*Hint hint Nudge nudge* |
#12
But what about momentum? Changing directions with a heavier bot it's going be be a bit harder I think... Or maybe not, I'd like to get some input on this. |
#13
I do have an idea for this, but I'm trying to stimulate the thinktank, see what else people come up with ![]() |
#14
car steering might make a comeback this year......seeing as how tank drive wouldent turnas well,(drifting around with the trailer would take some getting use to though)
#15
Some quick suggestions off the top of my head:
Giant Flywheel. For resistance to bumps and bruises, spin up a giant flywheel to help you conserve momentum. Traction Control. This was mentioned before, but I'll summarize the idea of a traction control system. In a car, you compare the speed of the powered wheels to the unpowered wheels. If there is a difference, that means one set is slipping while the other isn't. The computer cuts a bit of power to the driven wheels until both spin at the same rate. For a 4-wheel vehicle, you can use an accelerometer to get the differential measurement. Mariocart for Driver Training. Mariocart invented drifting. Blue sparks may be a safety hazard, though. Pneumatics as Thrusters. Satellites use gas thrusters to control direction. If the surface is low enough friction, this could act as a nice stability augmentation. Antilock Brakes. Antilock brakes don't necessary cut down on braking distance, but rather they give you control WHILE braking. If you slam on a car that doesn't have antilock brakes and you lock the wheels, the car basically keeps moving in the direction of its momentum vector, regardless of which direction the steering wheel is pointing (conservation of momentum). With antilock brakes, you're switching between static friction and dynamic friction, and in a nut shell, this gives you some control (ie allows you to swerve around the object you're braking for). Physics 101. Actually, Physics 8.01. For the truly adventurous, check out Walter Lewin's physics videos on MIT's OCW, specifically the lecture dealing with friction. http://ocw.mit.edu/OcwWeb/Physics/8-...il/embed08.htm. This is roughly equivalent to an AP Physics class. |
| EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? | mayazk | Programming | 2 | 16-02-2008 02:17 |
| New skateboard... Just imagine the robotics drive applications this would create | Elgin Clock | Technical Discussion | 8 | 21-07-2007 12:56 |
| How can this be!?! | Mike Rush | Math and Science | 6 | 09-12-2004 13:51 |
| How many drive motors did you use (per side) this year? | Billfred | Motors | 19 | 16-10-2004 20:27 |
| How can we make this better? | archiver | 1999 | 6 | 23-06-2002 22:39 |
