Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 03-01-2009, 21:25
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
Team Role: Driver
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: How can we drive on this new floor?
Originally Posted by Dracco1993 View Post
I still need help on thebluealliance thing please.
try here
http://www.thebluealliance.net/tbatv.../teambadge.php
Adam Spears
2010: Florida Regional Finalists.
2010: Goveners Award.
2010: Florida Regional Judges Award.
2010: UL Saftey award.
2009: Florida Regional Chairmans
2009: Rockwell Automation Innovation in Controll Award.
Unread 04-01-2009, 00:34
ScottX's Avatar
ScottX ScottX is offline
FRC #0047 (Chief Delphi)
ScottX is an unknown quantity at this point
haha its like a car on ice...=D
SCHOOL ROCKS!
Unread 04-01-2009, 00:40
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Obviously you don't drive the robot.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 04-01-2009, 02:59
PowerOfKings PowerOfKings is offline
AKA: Jon
FRC #1891 (BullBots)
PowerOfKings is an unknown quantity at this point
So Zyck_titan it seems you had the same idea I did... >.< and I thought I was original.
We did the math and with a 480 watt (the maximum wattage motor allowable) you could produce just under .2 psi. (allow variance for rotor blade type) Numbers for this were taken from a website publishing the Static Pressure capabilities of their 480 watt fans. (we then did conversions to psi)
Now you have to multiply by the square inches (maximum allowable 1064 = 28x38) and we get about 213 pounds of extra force.
So if you had a skirt around the entirety of your robot you could conservativly expect to roughly double the weight/normal force of your robot. (you'd lose a lot due to inefficiencies)
This means that when applied to F=MA in regards to your acceleration you can expect to take it from roughly .6 m/s (static friction with no fans) to 1.2-1.5 m/s (static friction with fans)
Now logistics might be a tad tough but hey if it gives you double your friction then it's worth it in my book. The real problem... ripping up the play area. If it isn't secured you would just vacuum it up and be completely stuck. This seems a real problem to me since when you look here ( http://thebluealliance.tumblr.com/po...field-elements ) at the end you can see the edge of the field which is merely secured with TAPE and now if this is a thin linoleum style roll you would just suck it right up and then... you wouldn't be able to move and might even get a penalty for destroying the field.
...after further research ( http://www.frpshop.com/pdf/installat...structions.pdf ) assuming FIRST followed these rules for the construction of a gasolenar frp floor it might not be too much of a problem...
Unread 04-01-2009, 07:37
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Alot of people's response to this problem reminds me of an exercise we had to do at a workshop that work had us do to advocate thinking outside of the box. They had us put up our hand and the guy would push it. Of course out of reflex we would resist. And he asked us why we resisted? Because it our habit to do so. Sometimes instead of just resiting the forces that are working against you is to loosen your control and work with those forces and allow them to do the steering.
Seems to me what people have the biggest problem here with is being in complete control of their robot and are trying to come up with every possible solution to regain that control when maybe the best solution is to embrace the lack of control and use it to the advantage like the guys who suggest the drifting training. You could waste alot of time and energy otherwise.
Unread 04-01-2009, 08:06
Dracco1993's Avatar
Dracco1993 Dracco1993 is offline
AKA: Jordan Miller
FRC #1741 (Red Alert Robotics)
Rookie Year: 2007
Dracco1993 is an unknown quantity at this point
Talking Re: How can we drive on this new floor?
Some of my team members and I calculated that using 2 sim's and suction cup properly you caould add an extra 600 pounds to your robot with ever touching the ground... Any Ideas?
Jordan Miller
___________________________________________
2010 Dean's List Semi-Finalist, Boilermkaer Regional
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 04-01-2009, 08:16
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Shade of 2003.
Teams used suction cups to plant themselves at the top of the ramp. That worked for the first few matches and then after getting ran over by robots for a while the field surface got worn down a bit and the suction cups stopped working.
I suspect the same would happen this year as well.
Unread 04-01-2009, 08:27
Dracco1993's Avatar
AKA: Jordan Miller
Rookie Year: 2007
Smile Re: How can we drive on this new floor?
Originally Posted by Koko Ed View Post
Shade of 2003.
I see your point, but that math was done assuming that the suction cups are about 1/2 to 1/4 of an inch off the ground. They would be more like a hover craft in reverse then suction cups.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 04-01-2009, 08:35
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
A hybrid of propulsion and wheels is almost useless even if it is deemed allowed (which by the "no other traction on the field allowed" part of the rules can't be done anyway).
I don't think it is useless. The maximum force that can be generated with the wheels for a max-weight robot is 26.7N. With some math, you can determine that 5N and 10N fans could be plausibly added to your robot, which would add 18% and 36% to the acceleration of a max-weight robot, respectively. Some of that would be eaten by the airstream hitting the trailer, but I think a fan approach could actually increase performance.
I think there is a reading of the rules where it would be allowed. Traction generally refers to the contact between a wheel and the ground. Fans aren't enhancing your traction with the field (and unless you have a quickly reversible fan, they actually hurt your braking performance), they are applying a force by pushing against the atmosphere. However, there are also readings of the rules where it wouldn't be allowed, and it'll have to wait until QA opens to see if they are allowable.
Unread 04-01-2009, 08:36
Dracco1993's Avatar
AKA: Jordan Miller
Rookie Year: 2007
Last year we were one of a few teams that used a vacume to pick up the ball so we have some experience with them. One of my friends on the team picked up the ball just using his mouth. He sucked on a vacume tube atached to a cake holder lid. With that much of a surface area he could pick up the ball for about 5 seconds.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 04-01-2009, 09:21
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Does this make any sense? Six wheeled bot. Four corner wheels driving forward and two side centered wheels driving backward as needed. Or, one wheel dead center of bot that would spin oppisite as needed. Then hand the whole thing over to programers. They can make it work.
Unread 04-01-2009, 10:16
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Look, all the ideas with fans:
Why not take your 200 pounds of force going downwards, point that to a side, and use it as a means of propulsion? It would certainly be a lot more efficient than using the force to increase the traction (it will still be low traction).
-Vivek
"we don't build robots, we build people"
Unread 04-01-2009, 11:09
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Would a holonomic drive system work well? I think it would make it easier to drive, but I don't know for sure. Here is a link to a picture of what I am talking about except that we would have to use the required wheels instead of the omnis. The required wheels should work as well though, because they barely have any traction.
http://wiki.chiefdelphi.com/media/0/..._holonomic.jpg
Unread 04-01-2009, 11:43
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
Rookie Year: 2007
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
You would have to use the wheels in the kit as the casters, the wheel would be huge and bulky but it could work. Now you have to know that an omni-drive works on the principle of wheel slippage. It is designed so that wheel casters slip.
  #15   Spotlight this post!
Unread 04-01-2009, 13:22
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
While this might make sense initially, holonomic actually starts looking very bad after viewing the COFs for the wheels.
10.2.4.1 Wheels
The wheels supplied in the 2009 KOP are very different from previous years’ kit wheels. The
tread material is Celcon M90, and has the following coefficients of friction on white, rippled
fiberglass plastic sheet
Inline, static: 0.06
Inline, dynamic: 0.05
Transverse, static: 0.14
Transverse, dynamic: 0.10
Yes, the transverse COF is very low, but the inline COF is less than half of it! This means a holonomic drive robot (with the COG in the middle) theoretically wouldn't move at all! In practice, it might, but not much.
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
