Go to Post The sign applause was definately one of the best moments I had ever witnessed at a FIRST event. Who knew silence could be so loud? - Koko Ed [more]
Unread 03-01-2009, 19:40
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Wide drive base have additional benefit this year?
If we just decide to go with skid steering, would having a wider drive base be really difficult to turn? I imagine with the surface it'll be hard with skid steering already.. But what are the cons to a wider drive base? carrying that trailer already makes you longer, so your footprint is larger anyways...
Comments you all have?
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 03-01-2009, 20:13
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
FRC #0461 (Westside Boiler Invasion)
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Re: Wide drive base have additional benefit this year?
In skid-steering, wide drive bases are typically easier to turn--longer drive bases are harder to turn. This is why in previous years, six wheel drives with the middle wheel dropped have been very popular--teams have wanted to have the "front to back" direction of their robot be longer, which poses issues for skid-steering, so when you have the six wheels with the middle wheel dropped, the drive base tends to be on either the front four or the back four mainly, so that the "effective" drive base is wider relative to its length.
So a wider base will make it easier to turn. This is because of the geometry of the wheels and how the forces and torques are applied relative to the ground. If you look at industrial and construction skid-steer vehicles that have wheels (some Bobcats, etc. come to mind) the wheels look relatively close together so that the drive base is wider than it is long.
Cons of a wider drive base include the fact that if your robot is mostly moving forwards and backwards than having your drive base be say, ~38" wide and ~28" long means it is more likely to tip. Also, it becomes more challenging to fit something like an arm in the box if it has to be front to back (obviously, these issues can be designed around, but they make life more difficult!)
I don't know for sure how the interface between the trailer and the robot looks but maybe it could help you retain front/back stability by keeping you from falling. Also, it is harder to tip when there is less friction with the floor, so depending on your center of gravity it could be very advantageous from a turning standpoint to do a wide base.
Just some thoughts.
Unread 03-01-2009, 20:18
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Fortunately, neither con applies to this game. It is very unlikely for a robot to tip this year and while arms CAN be built, they cannot extend outside the robots dimensions.
Unread 03-01-2009, 20:30
.999~=1
thanks Nikhil! That was helpful.
And yes, it does seem that the cons are minimal as tipping will be very hard with the trailer.. Hm. Good stuff to think about.
Unread 03-01-2009, 22:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
This whitepaper gives the mathematical basis for being able to turn. http://www.chiefdelphi.com/media/papers/1443
What new technology will FIRST have this year? Michael Hill Technical Discussion 23 13-11-2006 16:47
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
check out this lego Holonomic drive base Tytus Gerrish Technical Discussion 10 15-08-2004 17:47
How Many Motors Have You Dropped This Year? littleelectron Motors 5 05-02-2004 16:03
