Re: Question about missing Robots?
where's the rule that prevents three teams from having no robots and only players...they can't be scored on but they can still score?? I haven't found it yet!
Thats what Kevin is talking about. It'll prolly come up in the Q&A. Although I think they'll still leave your trailer out, for that reason. |
Well the trailers are still there if no one shows up. therefore it would be easier for the oposing team to score on the trailers especially since they begin at the opposing outpost station and furling ports.
I have seen no response from the GDC indicating that this is the case. |
I personally believe that the trailer will stay in its starting position if a team is not present. If the trailer is removed, this could potentially present a new set of strategic opportunities for an alliance. Based on the GDC's response to various questions in this year as well as years past, I do not believe they would create a situation where an alliance could say, "OK, team X that we're competing against in the next match has an awesome shooter(human or otherwise, you fill in the blanks yourself), so you(points to one team in the alliance) sit out due to a "broken" robot in this match. That will give them one less target to shoot for." Yes, the team would still have to have their Payload Specialist on the field to prevent a DQ, but the trailer would still be removed. |
Otherwise you can have an entire alliance agree not to put their robots on the field, and guarantee a worst case score of a tie, best case scenario a win (one of their human players score into the opponent's trailer). And if this was legal, why even build a robot? |
Although it isn't clearly specified and needs to be brought up in Q&A, I'd tend to agree that there will be three trailers per alliance on the field regardless of the number of robots, both to avoid providing a competitive advantage to teams that fail to bring a robot and to simplify field reset mechanics.
Based on past observation of match procedures, I expect Field Reset will probably reposition the trailers in their launch pads and reset the orbit balls to their proper starting locations while match N-1 is removing their robots. Then they'll flag the match N teams to bring in their robots, hitch up, and adjust position within the launch pad. This avoids having to carry the trailers in and out of the arena, which would have two negative effects:
What happens if a robot isn't on the field for a match?
Would the trailer still be placed on the field in some fashion? This would be difficult, considering that the trailer cannot support itself (it only has two wheels).
If a trailer is not placed on the field when the robot can't play, then an alliance with three no-shows would win every game. |
#10
Re: What happens if a robot isn't on the field for a match?
In your scenario, three no shows on one alliance would be a 0-0 tie, since neither team can score.
#11
I assume if your robot is no-show, than your team shouldn't be able to throw balls? Does anyone have a rule on this? I would like to see this clarified.
#12
Hm...weird, the actual rules dont say anything about this i think. I would say that a no show would in this case result in that each side would have one less hitch? i am really not sure
#13
Also something interesting to consider--If your team does not send a robot out for the match, but the alliance you were supposed to be on either doubles or triples the opposing alliances score, does your team still lose its game pieces the next match?
#14
There are two other threads about this already, both as inconclusive as this one will end up being:
http://www.chiefdelphi.com/forums/sh...d.php?p=790444 http://www.chiefdelphi.com/forums/sh...ad.php?t=71119 |
#15
Don't forget, the trailer is large enough that even without a robot it will still have something to rest against (the bumper would touch the ground before the wheels cause it to fall on its side). Considering that the robot would most likely be powering the lights in the first place (allowing for changed colors if needed) the trailer would be useless without a robot to power it.
| pic: Bots on Bots CD 47 | Mike Martus | Robot Showcase | 18 | 15-02-2007 12:40 |
| A question for ramp bots | Cody Carey | General Forum | 9 | 28-01-2007 22:23 |
| Art Bots | wildcatsfive | General Forum | 6 | 28-07-2003 19:09 |
| Bots v Bots | archiver | 2001 | 17 | 23-06-2002 22:06 |
| All these mouse bots gives me an evil idea- CAT BOTS! | Patrick Wang | General Forum | 2 | 09-03-2002 22:43 |
