Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Unread 04-01-2009, 11:15
2roy999 2roy999 is offline
FRC #1937
2roy999 is an unknown quantity at this point
jaguar brake\coast controlling
Hello,
I have looking in the jaguar getting stated guide
and I saw that you can give a signals to control
the brake/coast of the jaguar. On what component
of the control system and where should I connect
the second side of the wire?
thank you,
Roy Shmueli
team 1937
Unread 04-01-2009, 17:50
wireties's Avatar
wireties wireties is online now
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: jaguar brake\coast controlling
Wire this into one of your digital outputs.
Unread 07-01-2009, 17:58
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Originally Posted by 2roy999 View Post
On what component
Per <R60> if you want to wire the Brake/Coast Jaguar input, you must do so directly to the Digital I/O of the DSC. In this case, you should use a SINGLE wire between the signal of the DSC and the middle pin of the CB header (and only a single wire). To connect any other wire invites shorting unequal voltage sources or introducing additional current return paths.
Unread 07-01-2009, 18:16
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I had assumed we would need both 0v and signal to the CB port due to the optical isolation of the PWM input, which also appears to be the wiring shown on the Jaguar Getting Started guide. However it also states that all other (i.e. non-PWM) connections are referenced to power ground.
Thanks for the suggestion.
Unread 15-01-2009, 13:13
brianafischer brianafischer is offline
FRC #0503 (Frog Force)
brianafischer is on a distinguished road
To clarify this:
Using a DMM, our team checked the ground path between the Digital Sidecar ground and the Jaguar Brake/Coast Header ground. There was an open circuit (MOhm reading). We tested the Jaguar with a single connection which resulted in the DOUT OFF (0V/coast) state not working. Thus, we added a pull-down resistor (as stated in the spec sheet for the Jaguar) referenced to the GND pin of the Digital Sidecar.
2 wires on the digital sidecar, 1 wire to the jaguar.
Unread 30-01-2009, 06:46
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Originally Posted by brianafischer View Post
To clarify this:
Have you had any problem with getting the Jaguar in a coast mode using the jumpers? Also what spec sheet are you referring to and where do I find it.
Trying to help our programmers.
Doug Leppard
Unread 01-02-2009, 16:34
Coast and brake mode worked fine with the jumpers and as digital control lines with pull-down resistors. If the motors don't seem to be coasting, this is most likely due to the mechanical resistance of the drive train.
The spec sheet can be found on luminary micro's website: Getting Started Guide
Victor Brake/Coast Default FRC4ME Electrical 7 31-03-2008 13:40
Brake / Coast switching for Victors nreyesciena Control System 2 28-01-2008 13:17
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
