Go to Post This is what happens when Engineers try to design a sport. - Jim Zondag [more]
Unread 04-01-2009, 15:23
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Wireless Connection Problem
Hi gang, I've reseached this question but not found any answers, I hope someone can help.
Our wireless benchtop test has never passed. On previous Cheif Delphi advice, I went ahead and re-imaged the cRIO and DS with the latest loads (steps 5.1, 5.2, 5.3). All that went relativly smoothly. I also went through the wireless adapter configuration in step 5.6. But when I get to step 11 of 5.6.2 where you disconnect the DS router (WRT610N) from the Robot bridge (WGA600N), I get nothing. I’ve read in other posts were the laptop may have automatically turned on encryption which needs to be disabled. I've reconnected the two and ensured the security items are all off or disabled. I also noted that in step 8 c of 5.6.2, the words say set the DHCP field to start at 10, put the associated picture shows 1. Not sure which is correct but neither helped my situation. Also, I can ping the two devices when they are wired together, but when I disconnect the robot bridge, the pings to it go un-answered. Could our bridge be bad? Any ideas?
Jeff Austin
Mentor - Team 2930
Glacier Peak & Snohomish High Schools
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Wireless Programming FRC4ME Programming 14 14-04-2008 00:22
problem with connection seanl Programming 1 29-01-2007 10:41
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
