Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
Unread 22-01-2009, 12:03
agmlego's Avatar
agmlego agmlego is offline
Jack-of-all-trades
AKA: Andrew Meyer
FRC #0857 (Superior Roboworks)
agmlego is an unknown quantity at this point
Send a message via ICQ to agmlego Send a message via AIM to agmlego Send a message via MSN to agmlego Send a message via Yahoo to agmlego
Re: Implementing Traction Control for an advantage in the 2009 game
Our team is looking into implementing an algorithm we found for a four-independent-wheel-drive electric vehicle ETS, using four encoders and a gyroscopic yaw-rate sensor. We will be enhancing it with the accelerometer to detect sideways skid and report to the driver, if not correct it.
"I can guarantee that if it breaks today, it will be something that has never broken before"
--Arthur C. Clarke, The Trigger
Unread 22-01-2009, 16:25
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Right now Warren B and I are trying to get our arms around Paul's "middle income" solution. But for those of you going for the "super rich" solution, I have found a few interesting places to look:
http://scholar.lib.vt.edu/theses/ava...ed/Thesis2.pdf
and here's some observer and alpha-beta filter explanations:
http://www.mstarlabs.com/control.html
Check out "rough Data, Smooth signals" and "When One feedback isn't enough"
I expect SPAM'll compete with the "middle income" solution at the Florida regional
cool stuff
Eric
Don't PANIC!
S. P. A. M.
Unread 23-01-2009, 09:08
agmlego's Avatar
Jack-of-all-trades
AKA: Andrew Meyer
Hey, cool! I will definitely have the guys look in on those.
Unread 23-01-2009, 09:26
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Just a note:
We went to implement our accelerometer/encoder solution last night, and it wasn't as good as expected. This was partly because I hadn't totally thought it through and thought that simply comparing accelerations was going to be sufficient. I failed to realize the obvious fact that the encoder acceleration would not STAY above the accelerometer acceleration for long, so it is not a good way of telling when the wheelspin stopped. It was an excellent way of telling when your wheel started spinning, but since you can't easily detect when they stop spinning, the algorithm as I described it is not ideal.
We're going to have to get a bit more complicated, with either an estimated velocity from the accelerometer or a trailing wheel to get this working properly.
Unread 23-01-2009, 10:11
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
You can try integrating the acceleration signal to get velocity, and then comparing velocities to detect slip. The problem is that a noisy accelerometer signal looks even worse once it's integrated. For this and other reasons (one being the simplicity of an apples to apples speed comparison in code), non-driven encoder wheels lead to a better solution to this problem in my opinion.
Unread 23-01-2009, 10:34
Bongle's Avatar
Yeah, that's exactly what I'm thinking. Even with our rolling-average filtering, the accelerometer is ridiculously noisy.
Unread 23-01-2009, 16:24
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Originally Posted by cgredalertcc View Post
My final thought:
If the problem we face is that Traction=Normal Force * Coefficient of friction, and we have now way to increase our coefficient of friction why not increase the normal force? Last year 1741 used a very small vacuum to great effect in capturing balls. Why not apply the same idea to a robot? The area of the robot (28 x 38) is 1064 square inches if even 1/2 psi vacuum is applied to that area that is over 500 pounds of downward force. I know Bill has said that he doesn't like this idea, but he didn't like the idea of launchers last year, and look how many teams did that.
p.s. I know that last part isn't really traction control but its an idea I had that I wanted to throw out there. I guess the thought was who needs traction control if you aren't lacking traction.
Sounds like the legendary 1978 Brabam BT46B Formula 1 car which used an enormous fan underneath to generate a vacuum and more normal force. The car won the one race it ever competed in but was declared illegal
1139 Alumni
Unread 23-01-2009, 16:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We were given a +/-3g accelerometer, and our robots can accelerate at around +/- .05g (based on the published COF). Therefore, we can only use a ridiculously small portion of the range of the ADC.
The 2009 Control System Q&A Thread crake FRC Control System 59 11-01-2009 10:43
Drive train for 2009 game hihihiflcl81pig General Forum 4 27-12-2008 02:17
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
