Go to Post Maybe FRC WILL casue world peace, who knows, eh ? - Tottanka [more]
Unread 04-01-2009, 22:19
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Tell me more about the regolith coating.
Originally Posted by Elgin Clock View Post
The field wasn't slippery for walking on with the (dry) Vans sneakers I was wearing at Kickoff in Manchester for the official playing field, so I don't expect it to be an issue as long as you're not wearing high-heels to carry your robot on the field.
HOWEVER, be advised that when we went to pickup the kits, they had a sample of the field in FIRST HQ, and while my sneakers were the same, the snow we tracked inside made it MODERATELY slippery inside there on them material.
Bottom line is, as long as the field stays dry, & no one spills some soda or water on part of the field (or ruptures a compressor hose, and/or leaks some gear oil on the field) then it SHOULD be ok to walk on from a team member's standpoint most of the time.
Be cautions anyways, & always plan for safety first!
Yeah my shoes were wet too. In order to see the field at kick off we needed, and living in WI, there is always snow and wet outside. I could tell that the slip was because of the mass amounts of wet shoes on the field, not the field itself.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 09-01-2009, 03:27
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Originally Posted by Laaba 80 View Post
The field itself is not that slippery. What makes it slippery is the combination of the field and the wheels. They cant make the field to slippery because imagine what it would be like for Pilots carrying the robot on and off the field. We'd be slipping and falling constantly.
Joey
Well, I imagine drive teams will probably just slide their robots over to the gates this year, instead of wasting energy carrying it. We're goin' to the moon, it's all about efficiency (minus the millions of gallons of Kerosene and LOX we had to burn to get there)!
In all seriousness though, like Elgin said, this stuff isn't slippery to the sneakered foot.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 09-01-2009, 08:22
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by iCurtis View Post
... In all seriousness though, like Elgin said, this stuff isn't slippery to the sneakered foot.
I just hope we don't see any drive team members, referees, emcees, or other volunteers wearing acetal-soled shoes this year. On second thought, maybe acetal soles would be appropriate for some emcees.
Richard Wallace
since 2003
Unread 09-01-2009, 09:36
catsylve catsylve is offline
FRC #3538
Team Role: Coach
Rookie Year: 2007
catsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond repute
Alright, now Richard, just because you are spending all of your time sliding around on the highways between Missouri and Michigan, doesn't mean we have to make our emcees into hockey pucks as well!
2012 Woodie Flowers Finalist, St. Louis Regional
Unread 04-01-2009, 18:51
Brdn666's Avatar
Brdn666 Brdn666 is offline
AKA: Brandon
FRC #2604 (Metal & Soul)
Brdn666 is an unknown quantity at this point
Send a message via Yahoo to Brdn666
The regolith/field is the stuff used in shower walls. The plastic slightly textured I think. The rover wheels have less traction than the field itself. This was done most likely for safety and it's cheaper. Yes the field is slippery. Last year when our robot would be going at top speed and turned sharply, we'd slip. We had two wide rubber drive wheels are 2 cheap-o in line casters.
Unread 04-01-2009, 21:50
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
The Gel Coating reffered to is not a liquid or paste but a thin hard layer of plastic that is placed on the surface of fiberglass composit parts to improve the appearence.
When a fiberglass canoe is made a thin gel, an appearanece coat of colored resin, is put on the mold first followed by layers of glass and resin. This gives the outside of the canoe its nice appearance. On the inside you can see the cloth or fibers used to give it strength. The gel coat is usually hard and brittle and breaks easily without the fiber backing.
Unread 08-01-2009, 14:59
vannade vannade is offline
FRC #2591
vannade is an unknown quantity at this point
In checking out this product with the manufacturer there seems to be two types of Glasteel paneling, one with a smooth coat the other which can be bought at Home Depot (Glasteel wall liner panel sku #88594 49018) has a textured surface. Does anyone know which of these might be the right one.l
Unread 08-01-2009, 15:11
Carbon419's Avatar
Carbon419 Carbon419 is offline
FRC #1718
Carbon419 is an unknown quantity at this point
Yeah, i would have to agree with everyone else, that the "regolith" is basically a thematic name for the playing surface and it is basically ice. And yes ice saters do use it in the off-season to practice on becuase it is so slippery that it is an all around useful material, especially for this game.
Unread 08-01-2009, 19:49
Link2Everything Link2Everything is offline
Link2Everything is an unknown quantity at this point
Call me a necro for reviving a thread but I am looking through websites for teh coefficent of friction and its not adding up. Can anyone help me? I could just use a little.
Unread 09-01-2009, 02:09
ewilgus ewilgus is offline
FRC #2471
ewilgus is an unknown quantity at this point
Exclamation Re: Tell me more about the regolith coating.
SAVE SOME FOR US TEAM 2471, Camas, WA
Product Description:
Structoglas Class A fiberglass reinforced plastic (frp) wall
panels are durable, semi-rigid, and will not mold, mildew,
rot, rust, corrode, stain, dent, peel, or splinter. Panels
exhibit a high strength-to-weight ratio with
expansion/contraction values similar to aluminum
Distributor should be selected carefully for the fiberglass reinforced plastic (FRP). There are manufacturer FRP variations in this product and large price variances. If you buy a sheet from one vendor it may look different than product from another. So, buy all from one place.
Additionally, consider how will this material be stabilized on the substrate? In other words keep it from sliding all over the floor, especially with multiple sheets.
Compatible products are important choices for rapid protyping. Not sure if First uses Class Aor C. Product comes in smooth and texturized. Sample at kick off was texturized so I trust them to show us the correct thing.
Attached is a link to compatible product spec sheet in pdf format
http://www.cranecomposites.com/PDFs/2505_struc_tech.pdf
There are many Vendors selling this product locally. I suggest buying here.
http://www.lowes.com/lowes/lkn?actio...096&lpage=none
Sequentia
Fiberglass Reinforced Wall Panel
Item #: 8566 Model: 77096
4 x 8
Resin rich textured surface resists mold and mildew
Gencom Procurement Specialist
Crab Steering on Regolith Dan2081 General Forum 33 09-01-2009 16:35
Tell MSNBC About Your FIRST Team! Amanda Morrison General Forum 0 11-09-2007 09:33
Show off your team website picture galleries and tell me a little bit about them!!!! Elgin Clock Website Design/Showcase 14 30-06-2004 11:23
powder coating Ben.V.293 Technical Discussion 0 07-04-2004 22:46
Tell us a little about yourself... Dan 550 Chit-Chat 55 18-11-2002 17:37
