Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
Unread 04-01-2009, 16:23
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
Rookie Year: 2007
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Can't Download Code
I have downloaded code onto the robot many times, but now when I try to download code to the robot it gives me an error saying there is a "WTX TgtMem Error: Not Enough Memory" do I have to re-setup the Crio or is there a better solution.
Unread 05-01-2009, 17:52
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Re: Can't Download Code
How big is your program? It won't fit if it is too large. You may need to either downsize or optimize your code to make it fit. I'm thinking that this might be your problem, especially if you have, as you say, downloaded code to it several times in the past.
Also, you might want to try resetting the memory of the cRIO completely, then redownloading. Maybe some code fragments are clogging up the memory. But I really can't say either way, I haven't tried it out or researched into it enough yet.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Can't find 2008 Master code. Amisca Programming 5 07-02-2008 22:41
Can't download from Autodesk FIRSTbase Bomberofdoom Inventor 11 01-01-2008 20:06
2006 Robot Code Download Chris_Elston Programming 2 05-05-2006 10:42
CMU code can't find stdio.h MacFlightSierra Programming 4 11-01-2006 17:00
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
