Re: Round Belting - Solid vs. Hollow, Polycord vs. McMaster
I have a question about what rollers people are using with the polycord. Specifically for the drive roller and then the idlers. I had thought pvc pipe, but I presume there are other more elegant solutions available. Thanks.
No, it needs a larger pulley diameter because it is stiffer. The fact that it is rougher is separate and not really related.
Back at the Atlanta Championships in 2006 I got a sample of some yellow polycord for a team (sorry I don't remember which team) that is very rough almost like sand paper. It is 1/4" in diameter. I am not seeing something like it at McMaster but it is hard to tell. Does anyone know the exact stuff I am talking about and where to get it? Maybe a part number? McMaster says the metric stuff is "rough" but how rough? It doesn't say about the texture of the inch stuff. What polycord products have teams used successfully in the past? We can't afford to buy a bunch of this stuff to try out so need to limit the selection.
Good luck! |
In short, we found cutting the cord at 10% shorter to be pretty aggressive. At 3% shorter (instead of 10%) the balls moved just as well, and the whole assembly ran much smoother. Art, is there any reason for the half hour cure time? After five minutes or so ours were cool to the touch, and we haven't had any fail that were joined using your welding method. |
In 06 we used 5/16" clear urethane belting (solid core) and ordered the recommended 10% short. It was near impossible to get them onto our rollers. The process we had to go through to do it was so jerry-rigged and dangerous that I won't even describe it here. Not to mention the fact that once it was on, the efficiency of the entire system was horrid. I'd recommend more like 3-5% stretch for anyone else who hasn't joined their belts yet. |
As for the half hour cure time, again that's from the manufacturer recommendations. According to them, you can use the polycord after five minutes, but full strength in the joint isn't achieved until thirty minutes later. |
Remember, if you make belts 3% stretched, they can always be a made shorter... you can't lengthen belts.
#10
Dont see why you couldnt lengthen them. Just cut them and add in a piece just like you did to make the loop.
Bruce |
#11
BTW.. I just got done making 10 belts from 1/4 round solid urethane(orange) belting 10 percent short. They are tight but running on half inch steel shafts 10 inches long and in bearings they seem fine.
Bruce |
#12
I have bought poly cord in the past but we didn't put it on a 'production' robot.
During AimHigh a girl on a team from Florida showed me how to weld it. She used a lighter and heated the ends and pressed the ends together and clamped it. I cannot remember the setup hold times but if you setup a jig it should go easy. Also the cord is designed to have a certain amount of tension so you need to figure out how long you really want it then make the cables and then mount them. Think of them as tough rubber bands. If you know someone that has a nice sheet fed Heidleberg press you can probably some some of this stuff in action. I'm gonna run on a little more while I'm here. FYI - we may make a conveyer out of timing belt, probably the XL size, and use plastic pulleys scattered across a drive shaft will filler between the pulleys. the filler will be turned down the the inner pitch diameter of the pulley. plastic pulleys are cheap and you can get them with single, double, and no flange. timing belt is made in large tubes then is sliced like a giant salami. you can go buy any width timing belt you want if you order it from www.econobelt.com or www.sdp-si.com , for example 2 foot wide if you like. There are whole families of standard length. and the belts don't need to be as wide as a moon rock, only wide enough to touch the crown. and similiar to the timing belt, you can get flat belt (un-timing belt). right after we shipped aim high robot I went to a Harley Davidson bike ralley and saw some custom bikes with 4 inch wide belts driving between the engine and wheel. It was totally cool looking and had graphics imprinted onto the belt. does anyone know how to do the printing ? |
#13
Is the grip with the polycord similar to surgical tubing? |
#14
Having handled both lately, the polycord feels a bit grippier. I can't offer you any better insight with regard to hard figures, but there's a difference.
I've had bum experiences with hot plastics in the past, which makes me leery of using any custom heating rigs. That said, I also wouldn't want to use some bum setup with hollow-core belts. Has anyone had bad experiences with them in an FRC setting? |
#15
if anyone wants to try this with the solid core go ahead and save yourself some money and buy "WellerŪ/PortasolŪ Super-pro Self-igniting Butane Soldering Iron Kit"....it has a chiseled tip and work like a dream, plus its like $60 as opposed to $500 |
| Hollow Shaft optical encoders | magical hands | Control System | 2 | 24-03-2005 09:12 |
| Hollow Shaft optical encoders | magical hands | Robotics Education and Curriculum | 0 | 03-02-2005 22:56 |
| Polycord Belting | Claires4sorrow | Technical Discussion | 1 | 31-01-2004 13:37 |
| solid edge solid works | ceileachair | Inventor | 1 | 21-01-2003 22:03 |
| HELP! ChiefDelphi needs Green 1/4" polycord! | Brandon Martus | General Forum | 1 | 14-03-2002 19:25 |
