Go to Post The toughest regional that matters is the one you're in! - pfreivald [more]
Unread 04-01-2009, 23:02
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
Rookie Year: 2007
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Lightbulb Two Windriver Tips!
Hey CD!
whether or not anybody finds this post useful is irrelevant. Maybe it will slip down into the archives, maybe not. Hopefully, someone who is facing similar problems as I was will find this post in a search and be helped!
• When installing windriver, you need to select the "DISK_SERIAL_NUM" option at the screen which asks for a Host ID. [This is in the install manual PDF, I just missed it]
• When creating a project, in order to include WPILib properly, do this exactly:
-File->New->Project..
-In the "Select a Wizard" dialog, choose Examples->VXWorks Downloadable Kernel Module Sample Project
-Choose the starting point which suits your project best. We chose "FRC Simple Robot Template"
-It should open and build the sample SimpleRobot demo using the included WPILib binary. Set up the SVN WPIlib source update once they release the SVN info.
Failing to start the projects in this way [if you are not familiar with Windriver] results is it being impossibly hard to link in the library..
I hope this helped someone
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
WindRiver C++ Specific Keywords kyungjin C/C++ 8 01-02-2009 12:42
how to install windriver!! mole Programming 4 30-12-2008 12:52
windriver projects nickmagus Programming 4 01-12-2008 23:29
