Go to Post Failure is in my eyes, the key to success. If you can deal with failure, look it in the eye, and conquer it, the hard stuff won't really intimidate you any more...and you can only get better. - Andy Grady [more]
Unread 05-01-2009, 00:15
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
4WD Turning Difficulties
I wanted to bring this helpful "white paper" to the attention of people who are busy designing their robots in the mistaken belief that turning on a slippery surface will not be an issue.
If you build a 4WD skid steer robot in the "traditional" or "narrow" (wheels aligned with the long axis of the robot) orientation there is a very good chance that your robot WILL NOT TURN.
I know this might seem counterintuitive, but run the spreadsheet in the whitepaper with the coefficients of friction for the wheels (KoP list / section 10.2.4.1 of the manual as I recall) and look at the results.
Now keep in mind that in order to spin the trailer about your robot you will need to apply about a 3 lb force (30lb trailer weight estimate x .1 transverse dynamic coefficient of friction) at a distance a couple feet away from your robot's centre of rotation. So, say about 6 lb feet of torque.
In this case even a 6wd robot (with the middle wheels dropped a bit) will have difficulties turning in place... it will do it, but slowly.
And thank you to Mark from 1189 for posting the white paper and spreadsheet.
Jason
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
