Re: 4WD Turning Difficulties
If you have not hooked up a trailer to your robot, do it.
It may seem optimistic when you are driving just the robot, but as Paul said, it is just PAINFUL to drive with the trailer on. |
Really? We've had a different experience. I find driving with the trailer is more enjoyable. Sure, there is a slight loss of control at first, but once you get the hang of it you can pull some really nifty tricks. That said, you need a pretty big practice area to get the hang of driving the thing. From a dead stop, driving really slowly we can barely make an about face on two sheets (with the trailer on).
Think of being on ice. The smaller the tire foot print, the higher the psi, and thus.... better the traction. Let's say the wheel provided has a footprint of 1 square inch, your robot comes in at 120 lbs and you have 8 wheels with the weight evenly distributed. Then you have 15 psi. Go to 6 wheels and your at 20 psi. Go to 4 wheels and you are at 30 psi, 2 wheels.... I think you get the idea.
Ideally, one wheel would be best. Let me know how to make that work. I'm still in search of a very large bucket! ![]() |
Thanks |
| IR Difficulties | AmitCarmeli | Programming | 3 | 11-01-2008 20:49 |
| Technical Difficulties | muy dificil | Programming | 0 | 13-10-2005 11:25 |
| Default Code Difficulties | Drok00 | Programming | 3 | 02-02-2005 20:56 |
| FIRST Technical Difficulties at Rutgers | aka Scott White | General Forum | 10 | 27-03-2002 14:40 |
