Go to Post There's a fine line between insanity and healthy obsesion with FIRST ... and sometimes I wonder which one I'm on - srawls [more]
Unread 05-01-2009, 00:15
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
4WD Turning Difficulties
I wanted to bring this helpful "white paper" to the attention of people who are busy designing their robots in the mistaken belief that turning on a slippery surface will not be an issue.
If you build a 4WD skid steer robot in the "traditional" or "narrow" (wheels aligned with the long axis of the robot) orientation there is a very good chance that your robot WILL NOT TURN.
I know this might seem counterintuitive, but run the spreadsheet in the whitepaper with the coefficients of friction for the wheels (KoP list / section 10.2.4.1 of the manual as I recall) and look at the results.
Now keep in mind that in order to spin the trailer about your robot you will need to apply about a 3 lb force (30lb trailer weight estimate x .1 transverse dynamic coefficient of friction) at a distance a couple feet away from your robot's centre of rotation. So, say about 6 lb feet of torque.
In this case even a 6wd robot (with the middle wheels dropped a bit) will have difficulties turning in place... it will do it, but slowly.
And thank you to Mark from 1189 for posting the white paper and spreadsheet.
Jason
Unread 05-01-2009, 07:42
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 4WD Turning Difficulties
Jason
No problem, although I must give credit where it is due. Chris Hibner put together the white paper upon which my spreadsheet is based. http://www.chiefdelphi.com/media/papers/1443
Chris did all of the heavy lifting.
Mark
Brick walls are for other people. - Randy Pausch
Unread 05-01-2009, 01:18
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
I also ran this scenario through a drive train simulator and came up with similar results. Straight was perfectly as expected, but turning was near impossible and took forever. Add the sliding effect to it and your robot drive accuracy will take a nosedive.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 05-01-2009, 01:28
The Pre's Avatar
The Pre The Pre is offline
College kid who cant quit FIRST
AKA: JP
FRC #1652 (LakeView Legends)
The Pre will become famous soon enough
Send a message via ICQ to The Pre Send a message via AIM to The Pre Send a message via MSN to The Pre
what if you double or tripple up wheels?
stack wheels side by side so making a rough drawing using symbols
[ = wheels
| and _ = edges of robot
. =taking up space
________________
shouldn't something like that work? since there would be more surface area?
Unread 05-01-2009, 01:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's not likely to make any difference at all, since surface area has very little effect on friction with hard materials such as the wheel treads and arena floor.
Unread 05-01-2009, 01:35
The Pre's Avatar
AKA: JP
*sigh* 'ight thanks
so much for that idea, lol
Unread 05-01-2009, 01:38
The Voice of WNY
A couple members of our team did calculations for the majority of last night and more wheels don't help you at all. I would say 4 is the max you'd need for a drive train this year. We toyed with the concept of a 2 or 3 wheeled drive train but stayed with the 4 wheeled system mainly because of the contact with the side carpet.
I'd love to hear other opinions on this and how many wheels people are planning on using.
Josh Goodman
Unread 05-01-2009, 01:37
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Have you crunched the numbers on a wide 4wd chassis? I think it would work a lot better because the wheels have a lareger moment on the robot's cg, providing more turning force, and the trailer has a smaller moment, reducing the friction. I haven't done any of the math, though, and it may turn out that skid steer just isn't the way to go.
-Gary Forbes
Unread 05-01-2009, 01:50
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Simple skid steer is almost never the correct route to take. If i was going skid steer I would still be tempted to do something like a 6wd with a lowered center wheel to make the control of the robot more consistent (turning around the center) and to make the turning easier.
I would need to try some tests but even if I had the resources to build anything I'm pretty sure I would still go for the 6wd drive over a swerve simple cause the traction is so low a swerve could get excessively hard to control. Then again this isn't really a problem for me considering I'm mentoring a team with very little machining capabilities.
"History doesn't repeat itself - at best it sometimes rhymes" --Mark Twain
Unread 05-01-2009, 02:08
AKA: Jason Brett
Yes, the numbers for a wide chassis are better, and for six wheel drive (with the middle wheels dropped a bit) are better still. Six wheel drive on a wide chassis, with the centre of gravity over the middle wheels naturally, is the best of the skid steer options. That goes for high friction OR low friction environments.
I suggest everyone who is interested in this download the spreadsheet and try their own numbers in it. You can simulate a six wheel drive with centre drop by assuming it is a four wheel drive with two wheels up in the air. Thus the wheelbase is the distance from the middle wheels to whichever wheels (front or back) happen to be on the ground. The CoG will also move towards the centre axle.
Of course these numbers are calculations and simulations, and need to be confirmed by experimentation. I suspect we'll be seeing some video of the first protobots up on youtube by the end of the week.
Jason
Unread 05-01-2009, 02:21
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
What about wheels like this?
.......__.......
.......__.......
When you want to turn, spin the front and back wheels (wheels on short sides). When you want to drive forward spin side wheels.
Another thing we've considered is "toe."
If the wheels are angled slightly at each corner, spinning all of them in the same direction will allow you to spin in place.
It will also take advantage of the superior transverse friction when driving forward. And will provide some braking to prevent the robot from coasting when making a hard stop.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 05-01-2009, 02:26
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
.......__.......
.......__.......
The wheel's tranverse friction is more than twice the inline (apparently).
Even though their friction sideways is probably less than the omniwheels we're used to on carpet, that doesn't mean they will slide sideways easily in this case.
It doesn't matter that the transverse friction is really low, it matters that relative to that, the inline friction is substantially lower.
Unread 05-01-2009, 02:32
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
Mentor
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Okay, so here is a crazy thought I had...
If you did a 4WD in the same configuration as a omni-wheel drive...
...(like this) (In the same fashion as "The Pre" )
|= Chassis Perimeter
// = Wheels
. = space filler
___________
Would the low amount of friction on the wheels allow
the robot to move like an omni-drive?
I don't know how slick the flooring is because I was not able to attend a Kick-off.
But from what I have heard, it sounds pretty slippery.
Any guesses on how well this would work?
Edit: Hachiban beat me to it!
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 05-01-2009, 08:38
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
|= Chassis Perimeter
// = Wheels
. = space filler
___________
I'm pretty sure that this would "work" but, without really being a physics person, and not having crunched the numbers, I would think it would be even worse than a 4wd with the wheels on the corners.
  #15   Spotlight this post!
Unread 12-01-2009, 23:35
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
You are correct. This will work, however, the math proves you are not getting the full force of straight in line wheels and mechanums have a tendency to be difficult to steer straight plus a tendency for the operator to over correct. That's why so many teams experiment with a gyro feedback to help drive straight and side to side. The low friction of the surface means that the gyro would try to stop a skid but only manage to spin the wheels really fast... the exact opposite of what you need. Slower speeds seem to give more control but they're... slower. speed will be a factor in this game almost as much as friction.
Just my 2 cents
Steve
|= Chassis Perimeter
// = Wheels
. = space filler
___________
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
