Re: Trouble With Installing Inventor 64bit Vista
by the way did anyone get inventor fixed after it showed the Windows message
Are you downloading the file over a wifi connection ? |
No, I'm using a wired connection. I originally downloaded the 32 bit version, and it worked fine except it said that it could not be installed on the 64 bit operating system.
I am over wifi. why is there a file size Limit on some wifi?
Alright, so lets talk about the problems we have AFTER downloading.
My mentor and I had the exact same problem; we're both running Vista 64-bit machines. We got the file okay, had Inventor up and running and then one day it just decided not to work. My computer was having trouble shutting down and when I started it back up it did nothing for about 20 minutes. I restarted it and when I did a window that I had never seen before popped up telling me that my computer could not start and that it was running through repairs to fix the problem. After that everything worked fine until I opened Inventor and while loading I got a message that said "This program has stopped working, Windows is searching for a solution." And that was the end of that. So far I've repaired, reinstalled, uninstalled, and am now in the process of reinstalling from square one. Anyone have any idea what is going on?!? |
Yeah, that didn't work either
I hope in future years, Autodesk provides a blueray or multi-dvd set for the 64-bit Vista install.
It seems many of the problems are due to either downloading or unzipping. |
Good Luck!
I'm still having a few issues and am not 100% up and running. I need to get the team account password to finish the licensing process (I tried to login to Autodesk with my FIRSTbase username and it balked) Then I don't know where to extract my tutorial files. ... and I never was asked to "install" them, just extract the files. And I can't find a FAQ about where to extract them ... Then, after manually selecting the project path to my downloaded directory, I didn't like how it put %20's instead of spaces, so I changed them ... and ever since, it won't get past the splash screen. Even after changing them back. sigh ... I'll probably remove everything (except the HUGE downloaded file) and re-install. |
I finally got 64 bit Vista up and running , The download of the program (8.7GB) takes at least 4 hours the extraction process (with default vista extraction tool) takes a couple hours Installation takes almost an hour 32 Bit was much easier and hopefully Autodesk improves the process for 64bit Vista users |
#10
Wow you must have a fast connection, it takes me 20+ hours to download. i'm on wi-fi tho.
| Installing Labveiw on Vista | mtnman1 | NI LabVIEW | 17 | 04-03-2009 18:10 |
| Installing windows XP over vista..... | John Gutmann | Chit-Chat | 5 | 30-10-2007 01:57 |
| Trouble Loading vista?? | BobC | Chit-Chat | 12 | 22-02-2007 00:51 |
| Inventor software trouble/ FIRST Base trouble | nasa-senpai | General Forum | 2 | 24-01-2007 09:15 |
| Problems Installing Inventor | Adam Shapiro | Inventor | 8 | 17-01-2003 22:45 |
