Go to Post We're not all autonomous robots who are preprogrammed to always follow rules blindly regardless of what they are. - Ryan Dognaux [more]
  #16   Spotlight this post!
Unread 07-01-2009, 13:32
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Requesting Physists Help With Friction
Though it's not exactly related to the topic at hand, this seems like a good place for "my mind is being blown by friction" questions. Can someone explain why there is a twofold difference in the friction coefficients quoted for the inline and transverse directions on the rover wheels? I'm having a lot of difficulty understanding exactly what mechanic comes into play to make that happen, since the material is smooth and appears to be essentially uniform.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #17   Spotlight this post!
Unread 07-01-2009, 14:16
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
My only guess is that once the rover wheels get scuffed up by spinning a lot, the grooves along the wheel (in the direction it spins) will have an effect on its grippiness sideways. So perhaps the numbers they gave us are correct only for sufficiently scuffed wheels. We ran our lightly-loaded kitbot on a somewhat dirty hardwood floor, and the wheels picked up some dirt and scuffs. I suppose with enough running with a heavy enough robot, they'll develop substantial grooves.
As for the actual question, surface area CAN affect friction if the surfaces deform. You don't see race cars with skinny tires because the bigger tires allow for more stickiness, and you don't see skates with large surface areas because it wouldn't generate enough pressure to melt the ice and create the layer of water that you actually skate on.
Requesting Parts from Igus neoshaakti General Forum 4 27-01-2008 20:08
Requesting T-shirts From Teams All Around Kmo General Forum 13 18-12-2007 21:40
Requesting 2006 default code CyDrive Programming 11 03-05-2007 01:55
Requesting Inventor Files Dylan Gramlich Inventor 3 05-11-2006 00:56
LINUX Users: Requesting beta testers jdong Programming 35 20-03-2005 13:28
