Thread Tools |
Rating:
Display Modes |
The Trailer measurements
Hello ,
Can somone please clarify the trailler hexgonal base mesurments by a picture or something ? what is the lenght of the Edges? what does 28'' inscribed diameter means? Thanks. |
Re: The Trailer measurements
The following links contain dimensions, drawings, and info about each part needed in order to build a trailer and the playing field.
![]() http://usfirst.org/community/frc/content.aspx?id=11624 http://usfirst.org/community/frc/content.aspx?id=11626 |
Thanks , but I didn't understend from this drwings the edge lenght of the hexgonal base . If you can right it down or draw it for those who don't understand , and In addition clarify what does " 28'' inscribed diameter " from the manual means the the drawings I will very appreciate it .
Thank you anyway ![]() Last edited by Nadav Gross : 05-01-2009 at 07:16. |
I don't know why they chose to use ordinate dimensioning for the drawings, it's needlessly confusing. (OD is great for CNC programming, but a pain when you are laying out the pattern on a sheet of plywood with a ruler) All the dimensions are on the drawing, but if you are not familiar with ordinate dimensioning it can be confusing
The side lengths are 16 1/2" (note the 8 1/4" Y dimension on the corner) and the perpendicular distance between sides are 28 1/2" (note the 14 1/4" X dimension on the vertical sides) |
Thank you , but Just to simplify , the edge of the hexagonal (the edge A in the picture) is 16 1/2" ? And what is the " 28'' inscribed diameter " ?
Sorry for the lack of understanding the technical english terms , and thank you for your answers! |
It is 28 inches from one side to the opposite side. Each corner is 120 degrees.
The inscribed diameter means, if you drew a circle on the inside of the hexagon that touched all sides, the diameter of that circle would be 28 inches. As in the blue circle in the hexagon. Hope this helps! |
I GUSS I SUCK AT GEOMATRY, PLEASE, HOW MUCH IS A??????????????????????
![]() A = ? |
Hope this clears things up even further.
Outdone i guess
#10
A = 16 3/16"
The 28" so-and-so means the parallel sides are 28" apart Last edited by NorviewsVeteran : 05-01-2009 at 19:06. |
#11
According to the drawing, half the distance (from the center to the corner) is 8 1/4" so that would make the side length 8 1/2", not 8 3/16.
| Attaching the Trailer | Eiske | Rules/Strategy | 6 | 04-01-2009 22:33 |
| Trailer Available for the Championship | OZ_341 | General Forum | 0 | 23-03-2008 07:25 |
| To Trailer or Not to Trailer? | Carol | General Forum | 14 | 25-06-2006 18:14 |
| Can you explain the diameter measurements used in bullets, wire and nails? | Morenoh149 | Technical Discussion | 3 | 28-08-2005 18:50 |
