Go to Post My opinion doesn't matter at inspection. - DonRotolo [more]
Unread 05-01-2009, 06:36
Nadav Gross Nadav Gross is offline
FRC #1943
Nadav Gross will become famous soon enough
The Trailer measurements
Hello ,
Can somone please clarify the trailler hexgonal base mesurments by a picture or something ? what is the lenght of the Edges? what does 28'' inscribed diameter means?
Thanks.
Unread 05-01-2009, 06:51
ginosoprano09's Avatar
ginosoprano09 ginosoprano09 is offline
Aldo Cruz
FRC #2585
Rookie Year: 2007
ginosoprano09 will become famous soon enoughginosoprano09 will become famous soon enough
Send a message via AIM to ginosoprano09 Send a message via Yahoo to ginosoprano09
Re: The Trailer measurements
The following links contain dimensions, drawings, and info about each part needed in order to build a trailer and the playing field.
http://usfirst.org/community/frc/content.aspx?id=11624
http://usfirst.org/community/frc/content.aspx?id=11626
Unread 05-01-2009, 07:14
FRC #1943
Thanks , but I didn't understend from this drwings the edge lenght of the hexgonal base . If you can right it down or draw it for those who don't understand , and In addition clarify what does " 28'' inscribed diameter " from the manual means the the drawings I will very appreciate it .
Thank you anyway
Unread 05-01-2009, 07:26
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
I don't know why they chose to use ordinate dimensioning for the drawings, it's needlessly confusing. (OD is great for CNC programming, but a pain when you are laying out the pattern on a sheet of plywood with a ruler) All the dimensions are on the drawing, but if you are not familiar with ordinate dimensioning it can be confusing
The side lengths are 16 1/2" (note the 8 1/4" Y dimension on the corner) and the perpendicular distance between sides are 28 1/2" (note the 14 1/4" X dimension on the vertical sides)
Former Mentor Team 1771
Former mentor Team 4509
Unread 05-01-2009, 07:44
FRC #1943
Thank you , but Just to simplify , the edge of the hexagonal (the edge A in the picture) is 16 1/2" ? And what is the " 28'' inscribed diameter " ?
Sorry for the lack of understanding the technical english terms , and thank you for your answers!
Unread 05-01-2009, 09:58
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
It is 28 inches from one side to the opposite side. Each corner is 120 degrees.
The inscribed diameter means, if you drew a circle on the inside of the hexagon that touched all sides, the diameter of that circle would be 28 inches. As in the blue circle in the hexagon.
Hope this helps!
Unread 05-01-2009, 12:52
FRC #1943
I GUSS I SUCK AT GEOMATRY, PLEASE, HOW MUCH IS A??????????????????????
A = ?
Unread 05-01-2009, 12:59
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Hope this clears things up even further.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 05-01-2009, 13:13
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Outdone i guess
Unread 05-01-2009, 19:04
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
A = 16 3/16"
The 28" so-and-so means the parallel sides are 28" apart
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 05-01-2009, 19:06
martin417's Avatar
AKA: Martin Wilson
Originally Posted by NorviewsVeteran View Post
A = 16 3/16"
According to the drawing, half the distance (from the center to the corner) is 8 1/4" so that would make the side length 8 1/2", not 8 3/16.
Attaching the Trailer Eiske Rules/Strategy 6 04-01-2009 22:33
Trailer Available for the Championship OZ_341 General Forum 0 23-03-2008 07:25
To Trailer or Not to Trailer? Carol General Forum 14 25-06-2006 18:14
Can you explain the diameter measurements used in bullets, wire and nails? Morenoh149 Technical Discussion 3 28-08-2005 18:50
