Go to Post FIRST: there is no second. - BandChick [more]
Unread 05-01-2009, 10:57
KingBK's Avatar
KingBK KingBK is offline
FRC #1279 (Cold Fusion)
KingBK is an unknown quantity at this point
Re: Defensive Strategies
I really don't see a way to stop the other team from scoring on you. You could be able to put a lid on your trailer if you still fit in the dimensions but that is all your robot would really be able to do. I really think the best defense is going to be a good offense. Controlling the balls and making sure that you make them in the other alliances trailer before they make them in yours.
2009: Washington DC Regional Finalist (w/ 118 and 538)
2008: Bayou Regional Quarter-Finalists (w/ 499 and 945)
2008: NJ Regional Semi-Finalists (w/ 694 and 2016)
2006: NJ Regional Champions (w/ 103 and 25)
Unread 05-01-2009, 13:30
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
What if you just backed yourself into a corner of the arena and used your robot to block your goal? That could be useful end-game to prevent being supercelled by the other alliance.
-you're fired
Unread 05-01-2009, 13:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
not a bad idea but there is no real corner.
Unread 05-01-2009, 14:07
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Depends on how good the human players were. 1073 won a playoff match in 2004 when the human player threw a playground ball into the goal from clear across the field at the last second.
But I agree, this is not a bad endgame strategy if you have no other defensive options (i.e. no lid, etc).
e: you do have to keep in mind that there is a red payload specialist on the side of the field and vice versa...there is no location for the robot to be that is more than 20 feet away from a human player...
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 05-01-2009, 15:50
Petey's Avatar
Strategy & Gaming
AKA: Chris Peterson
What makes you say that?
Bio:
Unread 05-01-2009, 16:51
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Originally Posted by R3V34L View Post
Keep in mind that Balls removed from your trailer still count against you, and if there are more balls in the trailer, less can be put in. If you remove balls, you have to balance that with the possibility that you can now have more points scored against you.
I would personally say that the fact that a "moon rock" is put in at the beginning is a great advantage for the end of the match when there is less room for a "super cell".
as of now, and i hope moving forward, that is inncorrect information, unless you can show a rule that spicificly states this situation
Originally Posted by Tetraman View Post
It's not written in the rule book...but it is assumed though different rules.
<G07> B. If a TRAILER tips over, the points SCORED for that TRAILER at the time it was tipped will be preserved for the remainder of the MATCH.
your comparing apples to oranges. totally different situations.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 05-01-2009, 23:58
Bigflip2073's Avatar
Bigflip2073 Bigflip2073 is offline
&quot;Chyeah&quot;
AKA: Shane
FRC #2073 (EagleFarce)
Team Role: Electrical
Rookie Year: 2007
Bigflip2073 is an unknown quantity at this point
I was thinking about this for a while
how about using air cannons to deflect cells?
How much would it take to actually have an effecton an incoming cell?
Most likely there wouldnt be enough pressure and volume for there to have an effect on an orbitball.
however i dont think it has been tried
We'll get there.....
Eventually xD
Unread 06-01-2009, 00:27
R3V34L R3V34L is offline
FRC #0948
R3V34L is an unknown quantity at this point
Apologies for the incorrect information, however if you are allowed to descore, then, I would assume descoring from allies is also allowed. If from yourself, then why not your teammates? This would a low a single robot on you team to be designated a "descorer" perhaps with a conveyor-hook settup to simply go up to allies and remove balls through the grates of their trailers. This seems to be against the spirit of the competition, leading to my previous point.
I still believe that it is not a good idea however, as I mentioned before, one moon rock in at the beginning means less room for a super cell to be tossed in during the last 20 seconds.
Unread 05-01-2009, 15:29
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Originally Posted by 1075guy View Post
IMO, <G29> doesn't say anything about this. You're not grabbing, grasping, or grappling the TRAILER (an ARENA element), you're reaching into it, which is not mentioned, and therefore just fine.
But as soon as you start restricting its motion from the inside, I'd call that some form of attaching to.
Realistically, I think this will end up in Q&A very quickly. I would expect that the answer would be something to the effect of "As long as no rules on contact outside the bumper zone are violated, it's fine."
Which then means that all one robot has to do to get you in trouble is tangle you up. If it's done enough, you have to modify your design.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 06-01-2009, 10:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Firstly, vaguely restricting the motion of an object isn't "attaching" to it. Apply that definition to robots, and pinning a robot would suddenly count as attaching to it. It's more on the lines of entanglement, which is judged case-by-case, and you have to actually end up caught up with the trailer.
Secondly, if the GDC restricts this by the contact outside the bumper zone rule, it simply makes it slightly more tricky. Remember that you're descoring on a trailer attached to one of your partners. They have a vested interest in not screwing you up. Also remember that a robot can not be forced into a penalty by an opposing robot. If an opponent is trying to stop you from descoring and this causes you to violate a rule, you shouldn't be penalized.
defensive strategies Armando Rules/Strategy 74 14-04-2008 12:52
Defensive Strategies Goldeye Rules/Strategy 48 31-01-2006 19:16
YMTC: Defensive Strategies Matt Reiland You Make The Call 28 15-03-2005 15:11
Human player strategies? archiver 2001 6 24-06-2002 00:35
Best Strategies Rick Gibbs Regional Competitions 15 12-03-2002 09:23
